1-1/2" Tailpiece To 2" Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2016, 01:44 PM   #1
Rewards Points: 1,188
1-1/2" tailpiece to 2" trap?
Hi;
I've got what I think is a 1-1/2" brass tailpiece with dishwasher tee into what looks like 2" plastic trap.
I measured by running string around the circumference of each part and divided that by pi to get the diameter, so I am talking outside diameters.
In any case, the trap is definitely a larger outside diameter than the tailpiece.
The plastic nut securing the tailpiece into the trap is cracked/broken, and I just want to make sure I get the correct size. Alternatively, I can just take the broke nut off, but I really don't want to disturb the whole thing until I have the part to fix it.
I'll also replace the rubber gasket/seal on both the trap and the sink.
Any advice?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 11-28-2016, 04:11 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: 1-1/2" tailpiece to 2" trap?
They are both nominal 1.5". Buy a 1.5" compression nut and washer.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Ultrarunner2017 (11-28-2016)
Old 11-28-2016, 10:30 PM   #3
Thanks. I assume my local DIY store will have that.
pvc tailpiece to metal trap leaking nestor300 Plumbing 9 11-27-2014 09:59 PM
Adding utility sink for washer drain dcj710 Plumbing 16 03-22-2013 06:52 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
1 and 1/2" trap adapter for 2" drain pipe maxfischersweet Plumbing 5 11-19-2009 10:33 PM
