Wood Or Tiles? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree4Likes
  • 1 Post By 123pugsy
  • 2 Post By 123pugsy
  • 1 Post By marionbo
Old 05-16-2017, 03:10 AM   #1
Rewards Points: 6
Wood or tiles?
Good morning,
I'm going to renovate the house, and I'd like to make the floor again.
Now since I would like to put floor heating, I would like to know what better to have, whether wood flooring or tiles?
Tips?
marionbo is offline   Reply With Quote
Old 05-16-2017, 06:11 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,566
Re: Wood or tiles?
Tiles that look like wood.
de-nagorg likes this.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 05-16-2017, 12:01 PM   #3
Rewards Points: 52
Re: Wood or tiles?
I have heard horror stories of people putting wood floor over radiant heat. I would check with the vendor and see if they recommend it or not. I think you might have to go with floating to accommodate the movement in the wood with the heat.
Tiles that look like wood are amazing looking and are much more durable than hardwoods.
jnickel is offline   Reply With Quote
Old 05-16-2017, 02:53 PM   #4
123pugsy's Avatar
Re: Wood or tiles?
Here's some 4' x 8" porcelain planks I installed. They look very realistic.
kevk and marionbo like this.
Old 06-07-2017, 11:18 AM   #5
Rewards Points: 6
Re: Wood or tiles?
Thanks for your suggestions.
From another forum I was advised of the porcelain stoneware to be placed on floor heating. And in particular I was addressed to this French ceramic producer company. I discovered the advantages of the porcelain stoneware wood effect and I found a wide range of proposals.
123pugsy likes this.
Old 06-07-2017, 11:20 AM   #6
Rewards Points: 6
Re: Wood or tiles?
And this is the company:
http://www.novoceram.com/products/effect/wood-flooring
Old 06-07-2017, 05:58 PM   #7
Rewards Points: 898
Re: Wood or tiles?
What do you have for underlayment under those things?
BIG Johnson is offline   Reply With Quote
Old 06-08-2017, 04:34 AM   #8
123pugsy's Avatar
Re: Wood or tiles?
No heater wires under mine.
I used Schluter Ditra over the sub floor and then the tiles.
Old 06-08-2017, 04:36 AM   #9
123pugsy's Avatar
Re: Wood or tiles?
Originally Posted by marionbo View Post
Looks like they install them without grout?
That would make it look more natural I guess.
Old 07-03-2017, 01:35 PM   #10
Rewards Points: 20
Re: Wood or tiles?
Yeah check with your supplier, but if possible at all I would use wood. Wooden floors are beautiful!
DIYGuyDev is offline   Reply With Quote
Fake wood tiles mj12 Flooring 10 05-18-2016 11:23 AM
Need help identifying stained pallet wood. (pics) zpafk6 Carpentry 9 02-16-2016 08:41 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
