Window Treatment On Large Slider Door - Vertical Panels Vs Blinds (PIC ATTACHED) - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 05-13-2017, 11:30 AM   #1
Rewards Points: 244
Question
Window Treatment on Large Slider Door - Vertical Panels vs Blinds (PIC ATTACHED)
Hi All.. So we are looking for window treatments for our newly remodeled space. The one major design dilemma we are having is the large slider door (see photo). We are debating between:
1) Vertical Panels
2) Vertical Blinds
Our concern is we have a great slider with a lot of light coming in and don't want to block an entire pane of glass with vertical panels. So considering fabric Vertical Blinds so when fully opened the footprint is smaller.
QUESTIONS:
1) Vertical Panels, if we were to come out 5-6" on each side PAST the molding/trim vs mounting the track on the molding, so that when they are opened they cover less of the pane of glass, will that look ODD, the track coming out past all of the molding? (I have trouble envisioning the final design, one person said it won't look odd having the track past the molding)
2) Any thoughts on durability of Panels vs. Blinds (we have young kinds)
3) Any other advice or thoughts would greatly be appreciated.
THANK YOU!
Window Treatment on Large Slider Door - Vertical Panels vs Blinds (PIC ATTACHED)-fullsizerender.jpg
nutshellml is offline   Reply With Quote
Old 05-17-2017, 06:31 AM   #2
Rewards Points: 147
Re: Window Treatment on Large Slider Door - Vertical Panels vs Blinds (PIC ATTACHED)
I agree with your hesitation about panels (would not do it). I've had experience with vertical blinds: (1) Can be expensive. (2) Not good/will not last with small children, cats, and or dogs. Since you expressed an openness to other options ---give drapes some though: (1) Mounting is as easy (or easier) when compared to vertical blinds. (2) Wider selection of styles, colors, and you can choose fabric that allows as much, or as little, light to show through when closed. (3) Certainly easier to clean than vertical blinds. (4) When children or cats proceed to destroy them, drapes will be less stressful to replace than vertical blinds. Just saying ---Jaes.
jaes is offline   Reply With Quote
Old 05-17-2017, 07:16 AM   #3
Rewards Points: 7,813
You appear to have enough room for 'stackback' of pinch pleated panels clear of the glass. The casing to casing width plus 20% is a general rule for the rod face measurement.
Not willing to give up wall space? Consider flat panels with sewn on rings. These occupy less space when stacked back.
Vertical blinds are a good option if you buy a quality blind. Quality lasts; cheap does not.
Horizontal blinds for a filtered light look. Pleated horizontal or cellular shades mounted on the door or above retract to as little as 3" of vertical height on a glass unit of that size.
Lots of options out there.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Window treatment options? bokeh Interior Decorating 15 05-20-2017 10:04 PM
Installing horizontal blinds with window above godma Interior Decorating 2 09-30-2010 03:18 PM
Window Blinds? I see there is no listing.. monique6191 Remodeling 5 08-30-2010 12:26 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
