What Wall Corner Guards Do You Use Inside Your Homes? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree5Likes
  • 2 Post By chandler48
  • 1 Post By SeniorSitizen
  • 1 Post By Nealtw
  • 1 Post By JBoot
Old 02-09-2020, 04:24 AM   #1
Rewards Points: 271
What wall corner guards do you use inside your homes?
I have two wall corners that I want to put corner guards on :
1. Entryway wainscoting often gets banged by luggages
2. One kitchen corner (plaster) occasionally gets hit by pots.
Iím looking at stainless steel, aluminum. Iím also looking at vinyl/PVC but theyíll have to be painted since they seem to usually only come in white.
Do you have corner guards in your homes? Could you post photos? Iíd especially like to see how the metal guards look inside homes.
Iím also curious if decorative metal guards are available - you know, with texture or shapes/cut outs but they donít seem to be that common.
Druidia is offline   Reply With Quote
Old 02-09-2020, 06:14 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,002
Re: What wall corner guards do you use inside your homes?
Have you looked into outside corner molding? You can go to HD site and put that criteria in the search block and come up with plain, wood, metal, plastic outside corner molding. https://www.homedepot.com/p/Alexandr...096C/205576590
Druidia and lenaitch like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 02-09-2020, 08:13 AM   #3
Rewards Points: 5,682
If you're into wood working or have a friend that is you can be a real DIY'er and make your own corner beads of wood, with a profile you like or Plain Jane as ours required, for about 10 cents / ft. using Poplar lumber and paint. I made a couple dozen using Ash lumber when our house was built because that's what was the IN thing then and they're still doin real good.
lenaitch likes this.
Old 02-09-2020, 12:02 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,818
+1 on wood. We've used the self-adhesive 'plastic' ones but the glue dries out and you end up trying to re-glue them or use finishing nails, which don't work well since you are just going into drywall.
_________________________________________
Custodis pacis
lenaitch is offline   Reply With Quote
Old 02-09-2020, 12:23 PM   #5
Rewards Points: 1,790
We have bullnose that is 1" radius. It is metal underneath and covered by an intaglia type wall covering that looks like a knock down finish. (It is a manufactured home so it gives the walls a bit more strength and prevents cracking during transport.)
After almost 20 years, the corners are in surprisingly good shape.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 02-09-2020, 12:59 PM   #6
retired framer
Rewards Points: 13,250
Well protecting a corner with something that itself can get beat up, doesn't make sense to me. It is what it is use stainless steel.
Druidia likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 02-09-2020, 01:23 PM   #7
Rewards Points: 410
I have used these clear plastic corner guards in several areas where one wall had a wall covering ("wallpaper") and the adjoining wall was painted without a covering. This guard kept the covering from peeling and protected the doorways from basic banging and rubbing. It uses screws/nails to attach and the holes are already punched. It lets the natural background color show through and is almost unnoticeable.
What wall corner guards do you use inside your homes?-clear-plastic-wall-guards.jpg
Mike Milam likes this.
JBoot is offline   Reply With Quote
Old 02-09-2020, 03:57 PM   #8
Rewards Points: 271
Thanks mucho!
I didnít think of searching for ďmouldingĒ because when I think of moulding, I think of crown moulding.
Old 02-09-2020, 04:25 PM   #9
Rewards Points: 271
@senior , your wood corners do still look good.
But wood corners on my wood wainscoting will look overly woody.
I like the metal ones - thin enough to not make the corners look bulky and conspicuous. Theyíre aluminum. Depending on how glossy it is. I might have to just spray paint. Donít want shiny black on the corner. I have anodized dark bronze spray paint that looks quite classic. Iíll have to choose a spray paint color that would go nice with sort of khaki beige plaster (kitchen).
Now, if I could find stainless steel (so far, none in the HD website but saw them on Amazon), I wonít have to do any spray painting. Iíll see how the stainless steel looks like - if itís not too industrial looking. Our condo has stainless steel corner guards in the lobbies. They look very nice but also very office-like.
Iím tempted to go with aluminum because theyíre so cheap compared to stainless steel.
Jboot, that clear vinyl corner guard is what I currently have on the wainscoted corner. I donít like it. Looks too plasticky.
