What Diameter Curtain Rod For Blackout Curtains? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-07-2017, 04:03 PM   #1
Rewards Points: 48
What diameter curtain rod for blackout curtains?
I will be hanging curtains in the bedroom with these specs:
Curtain rod to be expanded to length of 95 inches
Curtain rod supported at each end & in the middle
Hanging 4 curtains on the rod, 2 on either side of the center rod bracket
Each curtain 53 inches wide & 84 inches long
Curtains are insulated blackout curtains
Can I use a 5/8 inch diameter rod?
Or should I use a rod with a larger diameter?
The smaller the diameter, the easier it is to move the curtains on the rod.
Thank you.
ClumsyGuy is offline   Reply With Quote
Old 10-07-2017, 04:08 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,882
Re: What diameter curtain rod for blackout curtains?
Moving the curtains is one thing, but the smaller diameter rod will sag with all that weight. I am assuming the curtains have weight, since they are black out. 7/8" is the norm in lightweight rods, but 1 1/8" will boost that rigidity you need.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-07-2017, 07:31 PM   #3
Rewards Points: 2,930
Get the curtains first & see how they look. Different curtains have different requirements for rods, whether they have a type of sleeve, tabs or rings to hang by.
Nik333 is online now   Reply With Quote
Small diameter roller for cut in? Homerepairguy Painting 16 12-08-2014 03:23 PM
double curtain wall system? stanfo3 Windows and Doors 2 11-22-2013 05:59 PM
Tub leaking past shower curtain Outbacker Plumbing 8 12-10-2010 04:15 PM
holes left by curtain rod screws/anchors..what to do? talula79 Painting 4 06-03-2009 09:05 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
