Water Spilling From Shower All Over The Floor!! Please Help! - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree1Likes
  • 1 Post By chandler48
Old 01-02-2019, 07:14 PM   #1
Rewards Points: 6
Water spilling from shower all over the floor!! Please Help!
Good evening, good people. On here trying to find a resolution for a very disturbing and consistent issue I'm encountering with my shower door. Every time I go and take a shower, the water from the shower leaks through the bottom of the door and spills onto the floor. There is a plastic barrier attached to the bottom of the door but even that doesn't prevent the water. What did the contractor do wrong? I called them and they came with the plastic barrier solution but that isn't solving the problem. DIY to the rescue. What can I do to simply have a functioning shower to where I don't have to worry about cleaning up water daily. LIterally every time we take a shower. Someone please advise and thank you all in advance.
Water spilling from shower all over the floor!! Please Help!-img_0599.jpg   Water spilling from shower all over the floor!! Please Help!-img_0600.jpg
Boogie560 is offline   Reply With Quote
Old 01-03-2019, 04:43 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,842
Re: Water spilling from shower all over the floor!! Please Help!
Lay a short level across the berm from inside to out. Is it level, or tilted to one side or the other. There should be a slight tilt toward the shower to help keep water inside. Any barrier they could have placed on the door unit should have been on the inside to prevent water from moving past. My bet is the pitch on the berm tile is incorrect.
Dave Sal likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-03-2019, 06:37 AM   #3
Rewards Points: 5,142
Try turning the shower head in the opposite direction of the door/glass.
ron45 is offline   Reply With Quote
Old 01-03-2019, 10:51 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 777
If the shower door opens outward, sometimes the water can hit the door and get past the lip at the bottom of the door. Ideally, the door should open inward, IMHO.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-03-2019, 12:45 PM   #5
Rewards Points: 923
If the top of the barrier is tilted towards the shower then I wonder if the seal on the bottom of the door is actually the issue. Could water be flowing around the vertical parts of the door and puddling on the outside of the door? If the seal on the bottom of the door is watertight, and water is getting on the outside some other way, there would be no path for it to flow back in the shower so it would spill on the floor instead.
Get someone to watch on the outside while someone else is taking a shower. Might be able to see the exact path the water is taking.
chiraldude is offline   Reply With Quote
Tags
bath and shower , shower leak
No hot water in shower, but works elsewhere. Please help! neatfreak Plumbing 14 09-18-2012 11:38 AM
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 06:47 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 05:36 PM
