Stripping Wall - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 09-16-2016, 08:11 AM   #1
Rewards Points: 4
Stripping wall
I'm currently stripping multi layers of wallpaper off and have come across what looks like black paint with a dark silver metal substance underneath it. Not sure what it is - any ideas?
Its on a wall that has an external chimney, so was unsure whether its a damp proof coating from the past? We believe the house was built in the 50's?
Cheers
Marky100 is offline   Reply With Quote
Old 09-16-2016, 03:03 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Stripping wall
We need a picture------might be one more layer of wall paper---or something odd---
More info needed--
Old 09-24-2016, 10:18 PM   #3
Rewards Points: 162
Re: Stripping wall
Sounds like some sort of heat resistant paper. Is it over the entire wall with the chimney, or just around the fireplace opening?
dlam9946 is offline   Reply With Quote
Load Bearing Wall? Master Brian Building & Construction 3 06-05-2015 10:32 PM
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 03:19 PM
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
