Shower Mirrors - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree2Likes
  • 1 Post By lenaitch
  • 1 Post By markg22B
Old 03-05-2018, 11:25 AM   #1
Rewards Points: 82
Shower mirrors
Problem: shower suction mirrors fail immediately due to non-smooth tile surface.
Previous solution: shower mirrors with a hook at the top could hang from the shower caddy.
These hanging shower mirrors seem to be no longer--all I can find are suction.
Assuming no one here has a hidden source for a mirror that can hang from a caddy, is there any reason the suction cup wouldn't work with the glass shower door?
Mark
markg22B is offline   Reply With Quote
Old 03-05-2018, 12:18 PM   #2
JUSTA MEMBER
Rewards Points: 2,118
Re: Shower mirrors
Stick your suction cups on the textured surface with rubber cement.
let the cement dry well before adding the weight to the cups.
Then when you want to remove the mirror, the rubber cement will clean up with a strong cleaner, and be gone.
Are your glass doors smooth or slightly textured also?
ED
de-nagorg is online now   Reply With Quote
Old 03-05-2018, 03:39 PM   #3
Rewards Points: 82
Re: Shower mirrors
Clever idea that rubber cement! I didn't know that it could be removed at a later date.
The shower door is flat, clear glass. Common sense says that once an area is well cleaned, it should be the perfect substrate for a suction cup. Then again...?
Old 03-05-2018, 03:49 PM   #4
JUSTA MEMBER
Re: Shower mirrors
Yep, rubber cement can be removed from most surfaces, not all, but most.
Some suction cups are not perfect, and won't hold to anything.
And after a time all suction cups will lose their ability to hold, and fail.
I have had them fail several times after they age, and crash their bracket, shelf, mirror, etc. to the floor. Many times breaking the object, that's all you need a broken mirror while you are in the shower.
The cup will hold to a smooth glass surface, until it ages and fails.
Is there anyway that you can attach this new mirror to the hook from the old one, If you still have it at hand, or maybe fashion something usable from a coat hanger?
ED
Old 03-05-2018, 03:54 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 1,240
Re: Shower mirrors
'They say' that 3M Command strips work in the shower, although I can't confirm that. If they work as well as they do on dry surfaces you should be fine. They come in a variety of configuations.
de-nagorg likes this.
_________________________________________
Pro patria
lenaitch is offline   Reply With Quote
Old 03-05-2018, 04:38 PM   #6
Rewards Points: 82
Re: Shower mirrors
I like the idea of the Command hooks. I'll give'm a try as plan A.
Thanks,
Mark
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 05:38 AM
General Questions w/ Pics on 1st Time Shower Pan Build/Install amodoko Plumbing 10 06-10-2015 02:45 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
