Protection From Heat Of Stovetop - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 12-18-2017, 07:16 AM   #1
Rewards Points: 2
Protection from Heat of Stovetop
I'm hand painting ceramic tiles (alcohol ink paint) which I'd like to put in the back splash over the kitchen cook top. Does anyone know of a sealer that I can use to protect these tiles? It must be a clear coat, must not yellow and must withstand the high temperatures radiated from the cooking surface.
Thanks for all and any replies.
Dyanlee is offline   Reply With Quote
Old 12-18-2017, 04:12 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,936
Re: Protection from Heat of Stovetop
Do you fire the paint into the process? I don't know of any heat resistant "clear" product, but I understand what you want.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 12-18-2017, 06:59 PM   #3
Rewards Points: 18,502
Heat rises, there's going to be very little heat even hitting the back wall.
Most just have painted drywall with no issues.
Can S1/S2 wire connect the Heat Pump? RichardS111 HVAC 4 09-30-2015 04:54 PM
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 03:34 AM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
