Opinions On Best Bedside Lamp Setup - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree6Likes
Old 01-21-2019, 10:27 AM   #1
Rewards Points: 132
Opinions on best bedside lamp setup
I currently have the master bedroom gutted for renovation and I need to decide what type of bedside lamps I will use and how they will be controlled. I will be doing the electrical work so cost and complication of installation is negligible. The questions are:
Table lamp or wall mounted? (I don't like hanging lamps)
If wall mounted, where is the best place on the wall to mount it relative to the mattress surface and mattress side
How should it be controlled? A) switch/pull cord on each lamp B) wall switches by bed, or C) 3 way switches by bed and door
What do you think and why? Thanks!
riccobo4 is offline   Reply With Quote
Old 01-21-2019, 12:17 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,256
Re: Opinions on best bedside lamp setup
Receptacles definitely placed on either side of proposed bed location. Never could figure electricians out when they put a receptacle directly behind a bed. It's sort of like dining room hanging lights. They are NEVER centered over where the potential table will go.
I would control general lighting from a switch near the door as you enter. For bed lighting it is convenient to have switches, but not necessary if the table lamps are reachable. My wife likes her sconce lamp to read by, but it is operated by touch control, and not a switch.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-21-2019, 12:31 PM   #3
Two Knots's Avatar
Rewards Points: 6,629
We have a ceiling fan with a light that operates from the entry door
and from the bedside as well.
We have table lights on our nightstands that
are reachable from the bed. Our headboard is wicker and iron; I took
advantage of the iron part (on my side) and have a small clip
on goose neck lamp for reading. Itís a small one with a short goose neck.
We also have outlets behind the end tables.
lenaitch likes this.
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is offline   Reply With Quote
Old 01-21-2019, 12:39 PM   #4
Rewards Points: 2,968
Those tacky touch lamps which look like they're from the 70's are great for the bedside.
I'm surprised no-one mentioned smart plugs or switches. Nowadays, you don't even have to reach over and touch the lamp. Just say "Alexa, turn off the bedside lamp."
Some day I may join the 21st century.
SeniorSitizen likes this.
CaptTom is offline   Reply With Quote
Old 01-21-2019, 12:58 PM   #5
Rewards Points: 132
I had considered putting the main ceiling light on a 3 way switch by the bed also. Do you find it useful or do you end up never using the bedside switch?
Old 01-21-2019, 01:41 PM   #6
Two Knots's Avatar
We have Alexa, operating the lights in the Living Room (4 lights) and the Family room, (2 lights)
but not in the bedrooms. The living room lights are on
timers as well.
I have one of those tacky lights in a guest room.
*Joann*
Old 01-21-2019, 01:43 PM   #7
Two Knots's Avatar
We use it all the time.
*Joann*
Old 01-21-2019, 02:29 PM   #8
Naildriver
chandler48's Avatar
Which side??? Veeewy important. Or go to a 4 way switch and install one on the other side as well.
Nealtw likes this.
Larry......
Old 01-21-2019, 04:06 PM   #9
Oso954's Avatar
Rewards Points: 2,114
Thatís the buyers problem. The receptacle was there first.
More seriously, the electrician was most likely working on a job were the builder or developer specified either NEC minimums or lowest price.
You can do up to a 12x12 room with 4 receptacles by centering them in the walls.
The electrician knows better than most that the bed is going to cover one of them. However, he has to make his customer happy, not the eventual buyer.
Oso954 is offline   Reply With Quote
Old 01-21-2019, 04:46 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 2,216
We had wall mounted lights on swinging arms in a couple of houses. They're okay until somebody decides to rearrange the bedroom. Our current house has half switched outlets with a 4-way on one side of the bed. It's not really handy because the builder mounted it too close to the corner of the room.
I vote for switched table lamps but do like the idea of the clip-ons if your headboard accommodates them. No experience with Alexa, Siri or any other techy controls. Do they still sell the Clapper?
Mystriss likes this.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 01-21-2019, 04:52 PM   #11
Naildriver
chandler48's Avatar
Another way would be to put a smart switch on the wall at the door and use remote controls to turn the lights off and on. That with another switch for general lighting would work, too.
Larry......
Old 01-21-2019, 04:57 PM   #12
Rewards Points: 66
one of the nicest, more recent things Alexa can do is that you can whisper commands and she can whisper back so you don't wake anyone up. Great for turning off outlets when the significant other is sleeping.
Toolmaker68 is offline   Reply With Quote
Old 01-21-2019, 05:10 PM   #13
Guapo
Rewards Points: 11,950
I despise lamps at eye level. So if an overhead light or pole lamp isn't an option. I would choose wall mounted light above eye level.
Guap0_ is offline   Reply With Quote
Old 01-21-2019, 07:40 PM   #14
Rewards Points: 1,706
I'd use remote switch outlets with a tableside lamp. My father uses a touch lamp, not tacky at all. Saves him from fumbling for switches. But I have a third in storage since the first didn't last very long. It is frost glass barrel and light is not too bright to read by. I don't know what it is with the quality, but one goose neck wall sconce sank with led bulb, I think the cooling and the electronics made the bulb too heavy.
carpdad is offline   Reply With Quote
Old 01-22-2019, 05:33 AM   #15
Mystriss's Avatar
Rewards Points: 7,354
One of my condos had built in reading lamps in the bed area. I hated them because it made it so the bed /had/ to go there, even though the bed would have been a lot better on the other wall. They were also a major pain to paint around (though that was related to the lamps themselves.)
My vote would be put in outlets on either side and use nightstand lamps.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Can I put a 9W LED lamp in a 35W HALOGEN fitting? schang1984 Electrical 4 01-29-2018 05:11 PM
Noobie question about wiring a lamp - any input appreciated! andrewss Electrical 28 10-31-2016 09:31 AM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Fluorescent lamp flickering Ash Electrical 11 08-03-2008 07:35 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 12:16 PM
