Need Help With Accent Wall And Trim - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 05-03-2016, 04:03 PM   #1
Rewards Points: 78
Need help with accent wall and trim
So my plan is to go pretty dark, maybe slate or charcoal, on the wall behind my bed and leave the other walls white or light grey. There are 2 doors on the wall opposite the bed/accent wall and 2 windows on the wall to the lefy of the bed/accent wall. I'm planning matching the trim of the windows and doors with the accent wall. My issue is there is a window on the accent wall which wouldnt benefit from the contrast of the other accents as it would be the same color as the accent wall. Any ideas on how to tackle or should I just go with the flow and paint the window on the accent wall the same color as the accent wall. Hopefully this doesn't confuse too much.
lexdiamond20 is offline   Reply With Quote
Old 05-04-2016, 11:25 AM   #2
Two Knots's Avatar
Rewards Points: 5,741
Re: Need help with accent wall and trim
Your post is a little confusing. Can you post a couple of pics of the room.
Two Knots is online now   Reply With Quote
New door installed, trim not square to adjoining wall (pics included!) MoreCowbell Carpentry 16 08-17-2013 04:57 PM
trim paint on the wall? dustycrockett Painting 14 06-20-2013 06:51 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 12:02 PM
