Mounting A Heavy Shelf To Hollow Bricks - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 11-10-2016, 07:34 AM   #1
Rewards Points: 36
Mounting a Heavy Shelf to Hollow Bricks
I'm wanting to hang a nice piece of oak I've found as a shelf on a bare wall in our kitchen.
The timber itself weighs around 10kg. We've got some very strong brackets, but the bricks we want to mount it to are hollow air bricks that have a tendency to crack as you drill through them. I get the drill bit through around 7mm and it just slips straight through into the air holes in the brick.
How can I neatly, and strongly mound this shelf so it's still very sturdy? Any ideas?
Thanks!
robnights is offline   Reply With Quote
Old 11-10-2016, 10:44 AM   #2
JUSTA MEMBER
Rewards Points: 2,340
Re: Mounting a Heavy Shelf to Hollow Bricks
Glue a mounting cleat to the bricks with PL construction adhesive.
Then mount your shelf to the cleat.
A 2X4 or it's equivalent will suffice as a cleat.
ED
de-nagorg is online now   Reply With Quote
Old 11-12-2016, 08:06 AM   #3
Rewards Points: 36
Do you mean like this?
We can place cleats along the back, and right side of the shelf, but not the left. Do you think this would suffice?
I've also got some hollow wall anchors. Do you think a mixture of the cleats, and anchors to hold the two brackets in place will be enough?
Thanks!
Old 11-12-2016, 10:33 AM   #4
JUSTA MEMBER
Those cleats are the general idea that I suggested.
Is there no wall at all on the left side , where you want to put this?
You might be able to run vertical cleats as well as the horizontals, to mount your brackets on, this would eliminate needing to rely on a hollow block to hold the mounting bolts. And the cleats would be mostly hidden if the shelf is below eye level. Run the verticals a foot or so in toward the center, this gives you support for the left side, as well as makes it symmetrical to look good.
Without seeing exactly what you have, I am guessing on some of this, but I do know that construction adhesive will hold the cleat until you pry it off, and then it will leave slivers behind. VERY STURDY.
ED
Old 11-23-2016, 10:30 PM   #5
Rewards Points: 616
tapcons.....
carmon is offline   Reply With Quote
Old 11-24-2016, 03:36 AM   #6
Engineer
MikeFL's Avatar
Rewards Points: 182
Drill into the head joints. That's where the mason puts the most mortar.
MikeFL is offline   Reply With Quote
Floating Shelf Concerns or Design Flaw? MrChompenstein Carpentry 12 04-14-2013 10:29 AM
Mounting shelf on tile wall brendalomax Tiling, ceramics, marble 7 12-12-2012 05:23 PM
Mounting a really heavy floating vanity properly around plumbing. brandonf Kitchen & Bath Remodeling 1 08-07-2012 05:09 PM
building shelf with questions.. typo Carpentry 2 12-29-2009 05:50 PM
Mounting a heavy oven tommy potatoes Appliances 1 03-27-2009 07:48 PM
