Mosaic For Bath - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree8Likes
  • 1 Post By Troy32
  • 1 Post By Nik333
  • 1 Post By de-nagorg
  • 4 Post By Troy32
  • 1 Post By sticky-tiles
Old 06-07-2018, 11:04 PM   #1
Rewards Points: 159
Mosaic for bath
I just finished tiling my bath up to the point I would like to add a 10 inch strip of mosaic. I have no idea what type of mosaic would look good. I think it should stand out a bit but not too much. I am good with installing not the design. I would really appreciate any ideas. Thanks
sticky-tiles likes this.
Troy32 is offline   Reply With Quote
Old 06-07-2018, 11:11 PM   #2
JUSTA MEMBER
Rewards Points: 1,162
Re: Mosaic for bath
There are several types, from a 1/2 inch wide strip, to another 12 inch wide tile in a different color.
And many colors and patterns to choose from, do a lot of research to find something that YOU or the SWMBO likes, As my tastes are different than you and yours.
ED
de-nagorg is online now   Reply With Quote
Old 06-07-2018, 11:15 PM   #3
Rewards Points: 159
Re: Mosaic for bath
We looked at a ton of mosaics but not sure what works. We are going to sell shortly so just looking for something that would be popular. Not really designing to our tastes.
Old 06-07-2018, 11:35 PM   #4
Home Repairer
Rewards Points: 468
Re: Mosaic for bath
You look like you have used large format tile but have not accounted for the use of a bullnose tile to finish the edges off. This would make installation of a mosaic much smoother to the finish of the tile job.
Choose any glass mosaic you like, but plan on a bull nose piece to finish off after the mosaic is installed.
czizzi is offline   Reply With Quote
Old 06-07-2018, 11:48 PM   #5
Rewards Points: 159
Re: Mosaic for bath
I used schutler jolly so no bull nose would be needed.
Old 06-07-2018, 11:53 PM   #6
JUSTA MEMBER
Re: Mosaic for bath
Then I would use a 1 inch blue as an accent piece.
Or another color to match some of the lesser colors in the field that you have now.
ED
Old 06-07-2018, 11:55 PM   #7
Rewards Points: 159
Re: Mosaic for bath
Here is the bathroom I just finished. Looking to do the same thing but looking for suggestions on a mosaic that will match the other tile.
Old 06-08-2018, 01:51 AM   #8
Rewards Points: 614
Re: Mosaic for bath
That's really beautiful & I don't even like the newer mosaic trend.
If that was your choice of design, trust yourself!
de-nagorg likes this.
Nik333 is offline   Reply With Quote
Old 06-08-2018, 04:19 AM   #9
JUSTA MEMBER
Re: Mosaic for bath
Yes Troy: that looks great. I would trust the instinct of whomever picked that out for that shower.
Go with your instinct, it looks right.
ED
cat's_pajamas likes this.
Old 06-08-2018, 05:48 AM   #10
Naildriver
chandler48's Avatar
Rewards Points: 914
Re: Mosaic for bath
You're selling, right? Put something neutral up there and rock and roll. Don't spend a lot of money nor time on it.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-12-2018, 09:43 AM   #11
Rewards Points: 58
Re: Mosaic for bath
Nice job! If you can design this shower then I think you can easily pick out a mosaic for your other shower.
interiordesign2 is offline   Reply With Quote
Old 10-10-2018, 08:00 PM   #12
Rewards Points: 159
Re: Mosaic for bath
Been a while but this is what we came up with
Old 12-21-2018, 11:50 PM   #13
Rewards Points: 6
Thumbs up
Re: Mosaic for bath
Just saw the result, I am a little bit late to the party, but it does look amazing! Love it how the colors look together
Malikasa is offline   Reply With Quote
Old 03-29-2019, 09:23 PM   #14
Rewards Points: 8
Re: Mosaic for bath
Actually, you can quick mosaic covering with peel and stick mosaic wall tiles.
sticky-tiles is offline   Reply With Quote
Old 03-30-2019, 01:13 AM   #15
Contractor/Engineer
Rewards Points: 1,170
Re: Mosaic for bath
I think 10" is too much - you want to have an accent, not a feature.
There are many glass/ceramic mosaics available - remain neutral with a hint of color - don't scream it - it a shower, for relaxing not disco.
Also, consider stacking the upper tiles in traditional, not subway pattern to give subtle visual interest - alternative, you could to the upper tiles on the 45...
Here's a couple of examples with the modest mosaic accent.
Domo is offline   Reply With Quote
Using a dremel to cut mosaic sheets Shelbie General DIY Discussions 2 02-13-2018 08:14 AM
thin skim coat ok on wall before installing mosaic? cubangt Tiling, ceramics, marble 0 07-24-2017 10:53 AM
Mosaic tile flush with ceramic Beepster Tiling, ceramics, marble 8 03-24-2015 03:31 PM
Tile backsplash with marble and glass mosaic ponch37300 Tiling, ceramics, marble 13 05-02-2013 09:38 AM
