Master Bath Mirror. - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree1Likes
  • 1 Post By lenaitch
Old 07-05-2016, 11:22 AM   #1
Rewards Points: 114
Master bath mirror.
DW wants to replace master bath mirror. Approx 46 wide by 50 some high. Actual size need only be enough to fit above single bowl vanity.
What am I in for? Looks like 2 clips on bottom solid into studs (?) then screw-in 2 more at top and possibly sides? Never did mirror before. If memory serves, good glass is heavy.
Just how much $$ are we about to spend? Ball park figures all we need for the moment - maybe she'll change her mind.
Thx
Sent from my SAMSUNG-SM-N900A using Tapatalk
ChuckTin is offline   Reply With Quote
Old 07-05-2016, 06:16 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,270
Re: Master bath mirror.
I can't comment on prices in your area but it will be much cheaper to select a standard-sized mirror (which I don't think 46x60 is) and beveled edge will look nicer. Mirror clips are pretty standard fare, they are sort of j-shaped with a slotted hole. The mirror rests in the bottom clips and you 'almost' tighten the top clips so they are just loose enough to slide down over the top edge. Finding studs will be nice but not essential since the majority of the load is shear (straight down).
lenaitch is offline   Reply With Quote
Old 07-05-2016, 08:38 PM   #3
Rewards Points: 114
Well time to get out the stud finder.
Cvt
Old 07-05-2016, 08:56 PM   #4
Usually Confused
lenaitch's Avatar
I suppose I could have provided the following link rather than mumble through a verbal description
https://knoji.com/images/user/hidden-mirror-clips.jpg
There are all sorts of different types, some more decorative than others and some better for heavier mirrors. Good luck.
tapestryqueen likes this.
Old 07-19-2016, 01:07 PM   #5
Two Knots's Avatar
Rewards Points: 5,035
What does the vanity look like? color of wood?
Go shopping and look for a decorative mirror that
is already framed and fits the decor.
It will most likely save you some money.
Mirrors, like everything have gone up a lot in price.
Two Knots is offline   Reply With Quote
Old 07-19-2016, 06:16 PM   #6
Rewards Points: 114
We found a good size / good price replacement at HD box store Website then had to track one down to a store medium distance away.
Am plesantly surprised she did pick out one that was "decor" rather than functional.
Install was straight forward - 2 clips at the bottom, set the mirror in centered left and right then 2 at the top then one left and one right.
All clips were on hollow wall hangers but the mirror was much lighter than I was guessing and there wasn't any of the mastic that I was dreading involved.
For once an easy job and we only bickered a little. DW and I work oh-so-well together. 😊
Old 07-20-2016, 12:23 AM   #7
Two Knots's Avatar
Well now, problem/project solved, now onto the next project!/problem!
Removing master half bath to extend main bath ryanb4614 Plumbing 18 08-27-2011 07:21 AM
Tiny Master Bath Remodel??? Orchdirector1 Kitchen & Bath Remodeling 14 10-30-2010 07:24 PM
Turning a Guest Bedroom into a Master Bath BbAaSsSs Remodeling 18 03-10-2007 05:03 PM
Advice on Converting Master Closet to 3/4 Bath Thirdeye Remodeling 9 02-13-2007 07:37 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 03:16 PM
