Laundry Door Ideas - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree4Likes
Old 01-20-2019, 01:09 PM   #1
Rewards Points: 28
Laundry Door ideas
I removed my bifold wood Laundry Door due to buying a new washer and dryer and the door no longer being able to shut without scraping up against the door of the washer. I'm looking for ideas for a practical door for the laundry room or if not a door an option to enclose the area that doesn't fold in or out. I haven't seen anything specifically for laundry rooms. Let me know if you have any ideas.
fenster4 is offline   Reply With Quote
Old 01-20-2019, 01:17 PM   #2
retired framer
Rewards Points: 8,778
Re: Laundry Door ideas
With a little framing you can bump the door out into the room a few inches so it clears the machines.
Nealtw is offline   Reply With Quote
Old 01-20-2019, 01:23 PM   #3
retired framer
Some times a full access kit is all you need
Beachmess likes this.
Old 01-20-2019, 01:34 PM   #4
Rewards Points: 28
My laundry room is flush with the wall though so the bi-fold doors on the right would not be able to fold out without obstructing movement of the washer or opening the garage door. I'm hoping there is an accordian style option that would not only be practical but aesthetic as well.
Old 01-20-2019, 01:58 PM   #5
Rewards Points: 28
HEre are pictures.
[/IMG]
Old 01-20-2019, 02:06 PM   #6
ZZZZZ's Avatar
Rewards Points: 1,862
I used a monster mini blind.
fenster4, Nealtw and Beachmess like this.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is offline   Reply With Quote
Old 01-20-2019, 02:25 PM   #7
retired framer
To bad they are not stackable, you could turn them sideways stacked. I don't see a good answer here.
Old 01-20-2019, 02:35 PM   #8
Rewards Points: 28
Nice monster blinds. Blinds have definitely crossed my mind.
Old 01-20-2019, 06:44 PM   #9
Mystriss's Avatar
Rewards Points: 5,548
Fabric roman shade might work better, less dents from the doorknob I'd imagine. You can make roman shades pretty easily with a sewing machine and some dowels.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 01-20-2019, 06:53 PM   #10
Rewards Points: 704
Using this (image) can you switch the washer and drier? It looks like the drier door may give you extra inch for cabinet type of door? Tall 3/4" ply door on a piano hinge? The doors don't have to be same size either. If you make that garage door trimless, you can put laudry door that's flat against that wall also.
carpdad is offline   Reply With Quote
Old 01-21-2019, 09:08 PM   #11
Two Knots's Avatar
Rewards Points: 5,035
How big is that opening? 6 foot?
The first thing I thought of is a accordion door that you hinge
on the left side. I did a quick search and only could find 36”
and 48” wide.
Perhaps you could buy two and attach them together to both open
from right to left. The price will not break the bank.
https://www.walmart.com/ip/Spectrum-...Door/107245215
Do a search for wider accordion folding doors.
Edit for after thought...What if you bought two and installed them so
that they both open to the left...With walmart free shipping (and you
can return it to the store,) you have the option of seeing if it would work.
https://www.walmart.com/ip/Spectrum-...3e&athena=true
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is offline   Reply With Quote
Old 01-21-2019, 09:12 PM   #12
Guapo
Rewards Points: 11,950
An accordion door would work.
Guap0_ is offline   Reply With Quote
Old 01-21-2019, 09:40 PM   #13
retired framer
I bought a washer dryer set cheap one time but it was in a closet like that but it had a 4 ft door in the center. What a pain to them out.
Old 01-21-2019, 09:41 PM   #14
retired framer
How much room between the machine and the drywall on both sides or each side.
Old 01-21-2019, 09:43 PM   #15
Two Knots's Avatar
what do you mean? It was a pain to get the washer and dryer out? Oh,
I think I know what you mean.
*Joann*
Musty smell from basement laundry room megaman Plumbing 13 06-19-2018 02:43 PM
Plumbing bathroom & laundry rooms zannej Plumbing 7 06-07-2018 04:53 AM
Adding 110v outlet in laundry room Gupta_amit Electrical 8 02-25-2018 04:36 PM
Enclosed Area (Laundry Room) within Attached Garage sMcGp Building & Construction 11 08-09-2015 06:06 PM
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
