How To Hang This Shelf - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree4Likes
  • 1 Post By SPS-1
  • 1 Post By craig11152
  • 1 Post By hkstroud
  • 1 Post By Koa
Old 08-27-2017, 10:17 PM   #1
Rewards Points: 6
How to hang this shelf
Hello,
I bought a pair of antique shelves (1960s) on eBay, but unfortunately they did not come with any mounting hardware or instructions.
There are two pieces of hanging hardware on the back:
I would like to mount them on this paneled wall:
I have tried to figure out how to put this up on the wall… I think they're intended to be used with a U shaped special bracket that acts as a hook, but I can't find anything like it in the hardware store. Would it be sufficient to just use a screw with a large head? Should I try to find a wall mounting hook that is low-profile enough to work? Any ideas welcome!
macchm is offline   Reply With Quote
Old 08-28-2017, 12:28 AM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: How to hang this shelf
Google "French Cleat"
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-28-2017, 12:36 AM   #3
Rewards Points: 6
Thanks! That would work, but I don't think that’s how it is intended to be mounted. I could replace that original hardware with a french cleat, but it seems less than desirable…
There's a better picture of the existing hardware at bit.ly/2iATFgV — it doesn't look like it matches the 45 degree notched french cleat hits I found.
Old 08-28-2017, 12:38 AM   #4
jlhaslip's Avatar
Rewards Points: 708
Having trouble with that link. Could you repost the full URL. Thanks.
Old 08-28-2017, 12:40 AM   #5
retired framer
Rewards Points: 8,582
If you find something like this that would fit in the hole and bend the top end out so it catches the brass plate. Then just screw it to the wall and hang the shelf.
http://www.homedepot.com/p/Everbilt-...5299/202033910
Old 08-28-2017, 07:09 AM   #6
Rewards Points: 9,780
I would just hang the shelf on a couple of screw heads. Hopefully the mounts are on the same centers (normally 16") as the studs in your wall. Screws should go into the studs.
ZTMAN likes this.
SPS-1 is online now   Reply With Quote
Old 08-28-2017, 08:55 AM   #7
Rewards Points: 44
Concur with SPS-1. You can use a round head or pan head screw. A bigger screw will have a bigger "shoulder". The shelf will be fine as long as it isn't bumped upwards. If that happens you might lift it over the shoulder of the screw. You could increase the size of the shoulder with a washer. It looks like the depth of the mounting slot is enough to accommodate a screw head and washer.
Your biggest challenge might be getting the two mounting screws at the right level. You will first want to make sure that the distance from the bottom of the metal mounting plates to the top of the shelves is exactly the same. If it is, then place your screws exactly level. If it isn't, then you'll have to adjust the height of one of your mounting screws.
When drilling the pilot hole for the mounting screw start with a small drill bit - its less likely to "walk" from the point you marked. Then enlarge that hole to the proper size for the screw you have chosen.
abrowning is offline   Reply With Quote
Old 08-28-2017, 12:52 PM   #8
craig11152's Avatar
Rewards Points: 1,220
I'm trying to wrap my head around 1960's "antiques". Did you mean 1860's
47_47 likes this.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 08-28-2017, 11:57 PM   #9
hkstroud's Avatar
Rewards Points: 6,494
Get the mending strap shown and some thick washers. Screw mending strap to the wall with a couple washers behind it for spacers.
Assuming that this is up.
Nealtw likes this.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 08-29-2017, 11:46 PM   #10
Rewards Points: 6
That’s genius! Thanks, I think that will work great.
Re “antique”, I suppose “vintage” is the better word. Just meant used, not commercially available new, didn’t come with a manual
Old 08-30-2017, 12:17 AM   #11
Koa
Rewards Points: 174
Home Depot has these in electrical dept...
Nealtw likes this.
Koa is offline   Reply With Quote
Old 08-31-2017, 07:13 AM   #12
Rewards Points: 170
Just take some pair of screws to hang the shelf. And see if the studs are in the level to get your shelf to be hang on your walls.
Hope! This will help you.
Mitaela Drayne is offline   Reply With Quote
Old 09-01-2017, 01:37 PM   #13
Rewards Points: 2
If you are having difficulty locating the holes try using stickymark. I found these on Amazon and eBay. I used them to locate drilling holes behind a painting. It's a 1" piece that has adhesive from one side and a pen from another. Adhere it to painting and slowly approach the wall. Put a level scale on painting for better result.
Go to Amazon and search for StickyMark. If you try searching for it on eBay ignore the autocorrect suggestion and stick to stickymark
Good luck!
Pelico is offline   Reply With Quote
Kitchen backsplash: install tile first, or attach shelf? ZZZZZ Kitchen & Bath Remodeling 2 07-28-2016 10:46 AM
Bedroom closet shelf BlueBSH Carpentry 6 09-24-2014 08:31 AM
Floating Shelf Concerns or Design Flaw? MrChompenstein Carpentry 12 04-14-2013 10:29 AM
Quick weekend project: Plant Shelf in Foyer hyunelan2 Project Showcase 1 01-04-2012 07:00 AM
nail bounces when hammered in wall. How do I hang shelf CarolPotter General DIY Discussions 7 06-30-2010 09:50 AM
