How Can You Do To Enhance A Small Bathroom? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree6Likes
  • 2 Post By Sam Wilson
  • 1 Post By CanadianRockies
  • 2 Post By SeniorSitizen
Old 11-20-2019, 10:56 PM   #1
Rewards Points: 8
How can you do to enhance a small bathroom?
Do you have a very small bathroom and you still want to have enough necessary facilities available inside?
In this post, I would like to share with you some tips to optimize the space of a bathroom and make it more convenient despite its square footage.
A corner sink
Overcoming the drawbacks of a pedestal sink which is occupying more space of traffic lane, a corner sink makes the use of the corner and optimize the space of the bathroom. Moreover, it is better to install a corner sink across from the toilet than the one across from the shower because of the shower door when it opens and closes.
A shower curtain instead of a glass door
Moving back and forth, a shower curtain will save much more space than a glass door that moves in and out.
Rounded vanity
There are two main benefits of rounding the vanity. Firstly, you can avoid sharp corners that might take more space and hazardous. Secondly, a rounded style often matches a square space, making it harmonious.
Large-scale patterns
These patterns can trick our eyes into seeing a bigger space than its real square footage that stays the same.
Donít use the shower door
Another alternative for the glass shower door is a glass panel. In spite of not being able to keep all the water in the shower, but almost all of them and occupy much little space, a glass panel is the best idea for a tight bathroom.
Bigger mirror
As you might have known, a mirror is one of the best methods to make a room look more spacious. Therefore, there is no reason to not use a big mirror in a less-than-ideal space condition in order to trick people's eyes. In addition, with a mirror stretching across the wall, two people can use the vanity at the same time.
A trough sink
Another type of sink that can be used in a small bathroom is a trough sink which is very narrow to be very perfect if you donít have enough space to install other sinks.
A wall-mounted faucet
Using this kind of faucet allows for a narrower sink or vanity, saving space for the total square footage.
Thank you for your attention!
Sam Wilson is offline   Reply With Quote
Old 11-24-2019, 05:26 PM   #2
Rewards Points: 18
Re: How can you do to enhance a small bathroom?
Fun wallpaper!
Leopard2 is offline   Reply With Quote
Old 11-25-2019, 03:03 PM   #3
Rewards Points: 58
Alternatively, some shower doors move along tracks inside the shower compartment.
https://www.homedepot.ca/product/gla...bay/1001196739
A corner sink
If you really want to optimize space in a small bathroom, then you could incorporate the sink into the toilet, with an added bonus of reusing your sink waste water. This idea is becoming especially popular in Japan and Europe.
CanadianRockies is offline   Reply With Quote
Old 11-25-2019, 03:27 PM   #4
Rewards Points: 58
Colors
Cool colors make small areas seem more expansive. Lean in the direction of greens, blues, and violets. Lighter values also expand a space. Predominantly apply a mint or seafoam green rather than a hunter or army green. Use darker shades sparingly to highlight focal features.
Lighting
Brighter lighting makes a room feel roomier. Bounce light off the ceiling to make the walls seem taller. Semigloss paint finishes reflect more light than flat ones.
jamerica likes this.
Old 11-28-2019, 08:00 PM   #5
Rewards Points: 54
It sounds very helpful to the bathroom to decorate, but when shower, water splashes to the bathroom too easily other space, cause the bathroom always very wet.Is there a good way?
CoolYeah is offline   Reply With Quote
Old 11-28-2019, 10:15 PM   #6
Rewards Points: 4,466
Yep, there is a good way. Turn the damm water down to a dull roar. OH BUT WAIT, we can't do that because we have to have that single handle faucet and for it to work correctly the flow volume must be to the point it slams light weight people to the back side of the shower and sticks them there.
Nik333 and lonnieashley1 like this.
Old 11-28-2019, 11:04 PM   #7
Rewards Points: 3,190
That would be hard on the back. Do you straddle the toilet seat? It's a small room.
Nik333 is offline   Reply With Quote
Old 11-29-2019, 09:30 AM   #8
Rewards Points: 58
I think most people approach the sink from the side, if there's room available to do that. There also are side-by-side toilet/sink combinations, which take up more space but still reuse the sink water.
lonnieashley1 likes this.
Old 12-27-2019, 11:03 PM   #9
Rewards Points: 366
Don't forget a TV for some depth and distraction!
JBoot is offline   Reply With Quote
Old 12-30-2019, 08:34 PM   #10
Rewards Points: 2,850
Go Euro style with the entire room having a slope to the drain. In that case a fixed glass panel is no problem at all (don't even need a step over).
Use a rectangular drain located against one wall so the entire floor gently slopes to the drain.
Install a pocket door entry so you have a lot more unimpeded area.
Can lights rather than wall mounted will also help, and lastly use crown molding and a smooth lightly tinted off white ceiling against darker wall to make the space seem larger (all white does not do this).
ktkelly is online now   Reply With Quote
Tags
virtual staging
