Hang Stuff On Walls - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 09-05-2018, 02:32 PM   #1
Rewards Points: 18
Hang stuff on walls
Hi, I've just moved to a new condo in Canada. It's a concrete-framed condo, but with standard drywall interior in the suite.
I've lived in a wood-framed house before, and whenever I needed to hang stuff (TV, photo frames, mirrors..etc), I would usually find the studs in the drywall to hang onto.
I'm curious what the drywalls are supported with in a concrete-framed condo typically? I've knocked on the walls to check, and I didn't seem to find studs behind the wall. Is that a typical construction for a concrete condo? If that's the case, how should I hang items on the walls?
Thanks for the help.
mister.jlin is offline   Reply With Quote
Old 09-05-2018, 04:25 PM   #2
Rewards Points: 4,536
Re: Hang stuff on walls
I would suspect wood or metal studs, otherwise the concrete has to be cut to run electrical.
stick\shift is offline   Reply With Quote
Old 09-06-2018, 05:33 PM   #3
Rewards Points: 86
Duplicate thread alert....
https://www.diychatroom.com/f101/han...1/#post5626367
Gregsoldtruck79 is offline   Reply With Quote
Tags
condo , hang , stud , television
Stone house wall insulation Huckleberry17 Insulation 17 10-19-2017 08:11 PM
Can I run electrical wire BEHIND my basement walls? GoBengals Electrical 8 01-18-2012 08:38 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Great Stuff Foam Between Walls chadwilliam1 General DIY Discussions 2 07-04-2010 06:37 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
