Glue Up Ceiling Tiles - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 09-02-2019, 07:44 AM   #1
Rewards Points: 12
Glue up ceiling tiles
Anyone have experience with these? They are light pvc type material, made to look like old tin. I have a 70's style kitchen with a dropped ceiling and popcorn on the actual ceiling. I have begun removing the grid and fluroscent lights.
These tiles look easy for a DIY on their website, but has anyone actually done this?
WhatdidIgetinto is offline   Reply With Quote
Old 09-02-2019, 08:06 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,276
Re: Glue up ceiling tiles
Don't know what "these" look like, but if they are 2' x 2', they will sit in your original grid. In all probability they do not "glue" up. We did color matching paint on the white grids for this install. They are so lightweight, you will need keeper clips to keep them from blowing up when a door is opened. Post pictures of what you have.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-02-2019, 10:46 AM   #3
Rewards Points: 12
I will not be using the grid, it's too low and has noisy florescents. These are made to glue directly over the popcorn ceiling.
Old 09-02-2019, 10:54 AM   #4
Naildriver
chandler48's Avatar
Do you have a link to them? I would like to see it. NOTHING can be glued over popcorn ceiling, FYI.
Larry......
Old 09-03-2019, 06:08 AM   #5
Rewards Points: 12
Old 09-03-2019, 06:28 AM   #6
Property Mgt/Maint
Rewards Points: 8,210
Looks time consuming but simple enough. If you have a true popcorn ceiling, it will need some prepwork like sanding and repriming. Might want to check with the mfg on the specifics.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 09-03-2019, 06:48 AM   #7
retired framer
Rewards Points: 17,326
I am sure they found a way to apply the glue for more than one tile at a time, 20 minutes drying time for each would take for ever.
If the room is out of square you best know that ahead of time so both sides get equal taper. and you have to decide whether the center of the room is the side of a tile or the center of a tile. Both ways.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 09-03-2019, 10:11 AM   #8
Rewards Points: 1,706
I've no experience with such tiles. But still suspicious enough not to use it. Sorry feeling only.
1. Light enough so just passes the code on what can severely injure a person?
2. Some kind of release glue on tile side (wax paper) and contact cement applied to ceiling. Glues can fail and the whole thing depends on the paint. Leak from above, example. Attic gets hot, so what does the heat do to the glues - one way to release contact cement is apply heat. How does pvc move with the heat/cold?
3. On a popcorn ceiling, that much less glue contacts (probably not a surface to surface but point to plastic surface contact).
4. Flange over flange, so repair could be difficult and edges not clean, esp the video tile that is not painted (caulking and painting can hide mistakes).
5. Popcorn or texture is not a flat surface. Tiles will follow this surface and I think the wavy nature will show once the tiles are installed.
I'd feel better if the tiles had screw holes (2 diagonal) with caps. 2 screws into the drywall could hold up each tile, I think, in case glue fails. Or there was a cap over the flanges so that I can use screws into the flanges and cover with snap on cap or such.
carpdad is offline   Reply With Quote
Old 09-03-2019, 11:37 AM   #9
Rewards Points: 11,064
Just to be accurate, that was a knockdown texture on the ceiling, not popcorn.
SPS-1 is offline   Reply With Quote
