Floor Lamp With Base That Doesn't Crumble Over Time - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree1Likes
  • 1 Post By Bondo
Old 04-17-2015, 08:43 AM   #1
Rewards Points: 265
Floor lamp with base that doesn't crumble over time
I have several floor lamps and they all have metal base covers. What's underneath though is a plastic mold filled with what looks like cement/concrete. The lamp bases can last up to more than a decade if they don't get moved or rarely get moved. But they do have to get moved when the floor is cleaned, and that's regularly. Floor lamps that get moved frequently last only a few years before their plastic and the cement inside crumbles.
Having to shell out $35-$60 every few years for a floor lamp is getting pretty tiring. I did fix a couple of floor lamps before by replacing the base filling with vinyl concrete and that worked out very well. But, I would prefer not to do any fixing if I can buy a floor lamp with a base that would not crumble and need to be replaced after a few years.
Has anyone purchased this elusive kind of floor lamp - no cement, concrete or plastic filling in the base? Are there floor lamps with solid wood or solid metal bases?
What have you done with your floor lamps once the base crumbled?
Druidia is offline   Reply With Quote
Old 04-17-2015, 02:44 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 396
Ayuh,.... That covers all the floor lamps I've got,....
Not that I Bought any of 'em,....
Mine all came outa dumpsters,...
The lamps are old enough, they've all got cast iron bases,....
Clean 'em up, alittle paint, rewire if necessary,....
Had one guy want his old lamp back, after I told 'im where mine came from,.....
Nik333 likes this.
Old 04-17-2015, 03:05 PM   #3
JUSTA MEMBER
Rewards Points: 1,894
I would find some old style barbell weights at a "GARBAGE" sale that are made from cast iron, adapt the lamp pole to go into the weight hole and use that .
ED
de-nagorg is offline   Reply With Quote
Old 04-17-2015, 08:40 PM   #4
Rewards Points: 6,652
I have never had that issue with floor lamps.
Old 04-17-2015, 10:05 PM   #5
Rewards Points: 1,928
A junked disk from a vehicle's disk brakes also makes a good heavy base for a lamp or anything. Put some rubber feet on it to keep it off the ground a bit.
ChuckF. is offline   Reply With Quote
Old 04-17-2015, 10:58 PM   #6
Rewards Points: 265
Thanks for the barbell weight suggestion but that is a lot more work than my current "replace with vinyl concrete" fix which takes less than an hour to do.
@Gregzoll - What's the brand of your floor lamps and where did you buy them? What are their bases made of?
My floor lamps get lifted and shifted at least once a week when I vacuum the floor. Some lamps get lifted and moved a lot more frequently for reading and DIY/craft work/tinkering. I think it's a pretty common problem since I've seen posts on other forums/sites complaining about floor lamp bases that crumbled. People, generally, just ditch the lamps.
Old 08-15-2017, 06:59 AM   #7
lorie86's Avatar
Rewards Points: 20
Re: Floor lamp with base that doesn't crumble over time
Maybe try the Brightech Eclipse LED lamp? The base is hard, sturdy, and feels very solid. I'm not 100% sure what it is made of, but it’s thin and small and very heavy so I assume it’s solid metal inside and out. The lamp pole is extremely thin too and is also made of metal so it can be moved quite easily without stumbling over. If you’re not into traditional base you can check out the Brightech Emma. It has 3 skinny wooden “legs” instead of a base and should not crumble when you move it because it’s quite lightweight. Just grab it on the upper side of the legs and you should be safe.
lorie86 is offline   Reply With Quote
Base molding help...need ideas Lillbush555 Carpentry 9 09-19-2010 07:38 PM
Water coming in at base of foundation Ptron Building & Construction 22 08-09-2010 09:51 PM
how to nail base cap of baseboard molding conradA Flooring 3 06-23-2010 11:57 AM
water base poly over oil base poly pappabear Painting 3 08-24-2007 01:53 PM
