Floating Wall Shelf - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 04-10-2017, 11:39 AM   #1
Rewards Points: 12
Floating wall shelf
Ok, I made a little rectangle floating shelf that's 19" long, 8 3/4" high, and just under 3.5" deep. I know where wall studs are and was planning on using them, however I am unsure on what I can get to hold it up. Total weight, with what I plan on putting inside it is 10.6 LB.
I assume I should plan on getting things to hold 11-15 LBS, however I don't have a lot of room to play with as the wood is only 3/4" thick, and I need almost all the space inside.
Given the constants of where it's going, floating is the only real option. The wood is left over from another shelving project I finished a while ago.
Is it OK to get some L brackets to hold this up? I was thinking of using four total, two on top and two on bottom with them all secured into the studs.
Thanks in advance for any advice/help/information.
1031982 is offline   Reply With Quote
Old 04-10-2017, 12:03 PM   #2
Breakin' Stuff
Rewards Points: 1,360
Re: Floating wall shelf
10 pounds is not very much, I would think L brackets would do just fine. And 3/4" is plenty thick for your basic shelf.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 04-10-2017, 12:53 PM   #3
Rewards Points: 12
That's great, Before I run out and buy stuff, what about this combination?
I am still new to this stuff, and would rather make sure before hand.
Forum won't let me post links yet, so I am looking at Home depot.
3/4 in. Zinc Plated Corner Braces
#6 3/8 in. Phillips Flat-Head Wood Screws
Old 04-10-2017, 01:09 PM   #4
Rewards Points: 12
http://www.homedepot.com/p/Everbilt-...5304/202033892
http://www.homedepot.com/p/Crown-Bol...1901/203086367
Old 04-10-2017, 01:49 PM   #5
Breakin' Stuff
I would get the biggest L bracket you can fit. Sounds like you are tight on room, but even the 3" one would be better. Get longer screws too. 1 1/2" maybe. Those little 3/8" screws won't even make it through the drywall.
Forgot to ask - when you say 8.75" high and 3.5" deep, do you mean it sticks away from the wall 8.75"?
The Following User Says Thank You to Bret86844 For This Useful Post:
abrowning (04-10-2017)
Old 04-10-2017, 04:04 PM   #6
Rewards Points: 12
It sticks away from the wall 3.5". Sorry for the confusion.
I went to a local hardware store and got it up using 3/4" bracket, included screws to secure the brackets to the wood, and 2" screws to secure it to the wall/studs.
Old 04-11-2017, 08:01 AM   #7
Breakin' Stuff
Ah, that makes sense. Looks like it worked out for you!
Need Some Advice About A House With An Issue neutropia General DIY Discussions 7 01-29-2017 06:46 AM
Plumbing a floating double sink vanity on an exterior wall HitLines Plumbing 3 08-16-2015 01:28 PM
Niche, Glass shelf to back wall? wraiththe Tiling, ceramics, marble 0 12-15-2011 02:46 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
