Diy Headboard - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 05-01-2017, 02:50 PM   #1
Diy headboard
Hello
I'm making a DIY headboard where I've removed the existing wooden slats on the headboard and have made a cushion (on mdf) to fit within the wooden frame.
What should I do to hold the cushion board in place?
It's flush with the back of the original wooden frame.
So at the moment the frame is empty with the cushion board now fitting into it.
Nij99 is offline   Reply With Quote
Old 05-01-2017, 03:38 PM   #2
JUSTA MEMBER
Rewards Points: 2,148
Re: Diy headboard
Install a couple of rails in the frame, then screw through the rails into the M D F, but not through the M D F.
That will hold the padded board to the frame, and not have any screw points to poke the back of your head.
ED
de-nagorg is offline   Reply With Quote
Old 05-01-2017, 03:43 PM   #3
How thick and wide should the rail strips be? What material?
Old 05-01-2017, 03:51 PM   #4
JUSTA MEMBER
Re: Diy headboard
1X6 clear (no knots) pine.
Divide the height of the space by 3, this will give you where to place the rails "on center" .
ED
attaching a headboard to a wooden bedframe BP1 Carpentry 2 06-12-2015 09:47 AM
DIY - Headboard from Reclaimed Pallet Wood Retroweld Project Showcase 1 06-12-2015 07:31 AM
Using OSB board to make a headboard? yummy mummy Carpentry 16 04-04-2012 07:25 AM
Headboard Fabric Swayne Interior Decorating 3 01-31-2011 08:27 AM
Headboard Question russ4bes Interior Decorating 1 12-12-2009 05:16 PM
