Direction To Run Tile That Looks Like Wood - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree9Likes
Old 09-28-2017, 09:40 PM   #1
Rewards Points: 916
Direction to run tile that looks like wood
Im laying tile in my bathroom. The bathroom is 9 feet long by 8 feet wide. The fixtures are all along the 9 feet of length.
The open width varies from 44" to 32". See attached diagram.
The tile is 12" x 24". Ideally tile that looks like wood should be run lengthwise. So that the grain lines up. See pic.
- But-
I'm trying to make the room look wider - and running tile width wise helps with that.
I'm not sure which way to run the tile.
Opinions , advice.
jaketrades is offline   Reply With Quote
Old 09-29-2017, 03:17 AM   #2
Rewards Points: 1,066
Re: Direction to run tile that looks like wood
If the tile is going to be noticeable, and I have ceramic tile that looks like wood in my bathroom that everyone notices and comments on, then you should stick with the convention and run it lengthwise instead of across. The reason is that it will stop your eye from following it the length of the room while not really leading your eye side to side to make the room look wider. In other words it will look like speed bumps in the road and subconsciously it will be perceived as a barrier.
This isn't an absolute rule however, so you should dry lay a few pieces down in both orientations before you get started to see for yourself which would look best. Sometimes the color, tone, and pattern of the material can have more of an impact than the orientation.
jaketrades likes this.
NotyeruncleBob is offline   Reply With Quote
The Following User Says Thank You to NotyeruncleBob For This Useful Post:
jaketrades (09-29-2017)
Old 09-29-2017, 07:22 AM   #3
Rewards Points: 898
Parallel to the long walls
BIG Johnson is offline   Reply With Quote
Old 09-29-2017, 08:39 AM   #4
Rewards Points: 916
I'll run them both ways and evaluate.
How long after I set the tile with thinset can I step on the tile?
How long after I set can I move my tile saw on top of the set tiles?
Cutting inside and the only option is to keep it in the bathroom.
Old 10-04-2017, 06:01 PM   #5
Rewards Points: 312
in a space that small, diagonally might look cool
KPDMinc is offline   Reply With Quote
Old 10-04-2017, 10:50 PM   #6
Rewards Points: 916
Way beyond my pay grade.
Out of interest what do you use to measure inside angles on the floor?
Old 10-05-2017, 12:55 PM   #7
Rewards Points: 312
i HAVE FOUND THIS TO WORK REALLY WELL...
http://www.homedepot.com/p/General-T...FQbgZAodUKMFsw
The Following User Says Thank You to KPDMinc For This Useful Post:
jaketrades (10-07-2017)
Old 10-05-2017, 02:29 PM   #8
Rewards Points: 4,552
I usually do a dry layout until I find what I like, including where to put the cut ends and how much to cut.
stick\shift is offline   Reply With Quote
Old 10-05-2017, 06:08 PM   #9
Rewards Points: 1,528
best advice.. do what stick said below... do a dry layout of different patterns and pick what you like.. thats all that matters...
With 12x24 also consider the pattern.. not just the direction. Many tile manufacturers suggest that you do a 1/3 type overlap.. vs. half..
ryansdiydad is offline   Reply With Quote
Old 10-07-2017, 06:48 AM   #10
Rewards Points: 916
Thanks for the advice. Ran it lengthwise.
Old 10-07-2017, 07:36 AM   #11
Rewards Points: 6
lloooks awesome!
siloowns is offline   Reply With Quote
The Following User Says Thank You to siloowns For This Useful Post:
jaketrades (10-09-2017)
Old 10-08-2017, 07:56 PM   #12
Rewards Points: 8
Looks great! Lengthwise was the way to go. Plus if your walls, an vanity, are the right color it will make the room look larger.
michelle1286 is offline   Reply With Quote
The Following User Says Thank You to michelle1286 For This Useful Post:
Old 10-09-2017, 10:34 PM   #13
Rewards Points: 916
What do you guys use to get rid of excess mortar / grout? Iíve been scrubbing it off with a damp scrub sponge, and hot water and paint scraper. Thereís still residue after many passes.
Iím considering using this tomorrow.
Old 10-10-2017, 06:37 AM   #14
Rewards Points: 7,785
Save your $20 and buy a gallon of vinegar instead mix with water 25% v to 75% h2o
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
jaketrades (10-10-2017)
Old 10-10-2017, 06:59 AM   #15
Rewards Points: 916
Really? That would be great! Iíll give it a shot. Vinegar wonít mess up the tile color?
Tile to wood floor transition stupid48 Flooring 2 02-18-2013 11:31 AM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Tile or wood baseboard in a home? Wahbehwoo Remodeling 4 09-27-2012 09:40 PM
Ceramic Tile or Laminate Wood Flooring PearlWhiteGT Flooring 5 01-10-2012 01:56 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 10:56 PM
