Crown Molding Seam Showing Under Paint! - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-10-2016, 05:12 PM   #1
Rewards Points: 2
Crown molding seam showing under paint!
I installed some crown molding recently and everything went well. All the angles were near perfect, measurements were spot on, and everything looks good... except for this seam that sticks out like a sore thumb. I sanded it flush and painted over it but it still shows through. Any suggestions?
Here are some pictures:
gralph is offline   Reply With Quote
Old 08-11-2016, 09:35 AM   #2
Rewards Points: 4,814
Re: Crown molding seam showing under paint!
I would say either you did not sand well enough or maybe something is bleeding through if you did not prime the wood before painting. Keep in mind fillers are a reasonable tool when painting wood.
stick\shift is offline   Reply With Quote
Old 08-11-2016, 07:39 PM   #3
Rewards Points: 1,956
Glossy paint tends to be unforgiving.
ChuckF. is offline   Reply With Quote
Old 08-26-2016, 02:35 AM   #4
Rewards Points: 234
I am home DIY painter (i.e. not a professional) but I think @ChuckF. is right. That your situation needs a lot and long of feathering underneath the paint of something that is not so reflective. Though I am not sure there is enough spackling or putty or low gloss paint that you can use underneath to create a smooth base.
Multiple coats, especially with some "coverage" coats underneath should help hide the seam but a sharp eye looking for imperfections may still notice.
RustNeverSleeps is offline   Reply With Quote
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 12:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Blotchy crown molding paint lewlewjones Painting 7 05-13-2007 03:31 PM
