Crazy Glue Not Keeping Plastic Together - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Like Tree1Likes
  • 1 Post By ZTMAN
Old 06-03-2016, 07:35 AM   #1
Rewards Points: 4
I have a clock with a plastic connector for hanging it on the wall. The connector broke and I'm trying to crazy glue it together. I followed the instructions and applied the glue to one side and it stuck, but as soon as I hung it, it fall right off the wall and cracked again. Do I need to use a pile of glue? Does Crazy Glue just not work on plastic as advertised? What should I do to make this repair?
King Bradley is offline   Reply With Quote
Old 06-03-2016, 08:02 AM   #2
Rewards Points: 8,602
Re: Crazy Glue Not Keeping Plastic Together
Hi King and welcome to the forum.
As you suspect, most of those advertisements are a bit optimistic. Not all plastics are the same so the Crazy glue may work as advertised on the plastic they are using.
I have repaired thousands of various plastic parts (office machine repair company) and never trusted the super glues. Where possible we added a metal component and often encased it with epoxy. Many different solutions for different problems.
Unless it is an expensive clock or you are just persistent, the time and effort will exceed the value. Can you give us a picture of the broken area?
Bud
Bud9051 is online now   Reply With Quote
Old 06-03-2016, 08:18 AM   #3
ZTMAN's Avatar
Rewards Points: 560
I gave up on the glue and keep the Plastic Weld Epoxy around for such things. Its a two part syringe and it works great. In your case super glue should have worked if you let it dry for 24 hours.
Bud9051 likes this.
ZTMAN is offline   Reply With Quote
Old 06-03-2016, 08:29 AM   #4
As ZTMAN suggested, I keep several of the 2-tube epoxy varieties around and one of them is specific for plastics. I have also done some extreme repairs with construction adhesive, Loctite PL 3X. Just repaired a cracked foot on my fiberglass ladder, like new. But it only comes in caulking tube sizes as far as I know.
One of the advantages of the 2-tube epoxies is a good shelf life.
Bud
Old 06-03-2016, 08:59 AM   #5
Rewards Points: 18,482
This is what I used after trying all the other ideas that where suggested.
http://www.bulbhead.com/lazer-bond-u...ufUaAlKz8P8HAQ
Bought mine at the Dollar store.
Easy to use, no waiting for it harden.
Old 06-03-2016, 09:25 AM   #6
Rewards Points: 4
Thank you.
Old 06-03-2016, 06:13 PM   #7
Rewards Points: 9,798
The trouble with the crazy glue is likely that it is acting on a very small surface area. Then, there is likely some bending stress on the joint too.
A picture would help, but for something like that, I would suggest epoxy putty. You knead the 2 components together, and then can "form" a hook out of it. Very hard -- some have metal fillers, put that's really not required for your application. The thing is, though, don't rely on "adhesion" to the back of the clock --- it needs a mechanical grip. Either the remnant of the hook has enough contour to ensure the putty can't let go, or perhaps drill a few small holes in the back so the putty can mechanically lock into it.
SPS-1 is offline   Reply With Quote
Old 06-03-2016, 06:32 PM   #8
The adhesive I suggested has fixed a pair of plastic sunglasses, a printer paper tray, the handle on a ceramic tea cup, hinge on a flip phone.
No mixing, no waiting, no having to add screws.
Carpet Glue woes ajussel Flooring 2 09-22-2015 08:41 AM
Need exterior glue advice mske390 Carpentry 7 06-25-2015 09:16 AM
need glue for soft plastic Ultrarunner2017 General DIY Discussions 10 03-24-2015 08:57 PM
Redgard vs 6mil Plastic Sheeting for tiling amodoko Remodeling 0 01-17-2012 11:57 PM
Glue (cement) for plastic and ABS agapediy Plumbing 13 04-18-2011 08:49 PM
