Bali 1" Vinyl Blind Replacement Bell Plugs - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 02-25-2018, 03:50 PM   #1
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 890
I installed two Bali 1" vinyl blinds and I attempted to shorten them according to the instructions, removing the small plastic bell plugs on the bottom rail. However, during the removal process three of them cracked and aren't usable.
These plugs are not replacement items available through Bali. I was wondering if anyone knows where to get these plugs, or can suggest a sensible work-around that looks neat and gets the job done. They're cheap blinds but I'm not buying new ones over a $0.02 piece of cheap plastic.
Thanks!
Thunder Chicken is offline   Reply With Quote
Old 02-25-2018, 07:24 PM   #2
Rewards Points: 1,394
Re: Bali 1" Vinyl Blind Replacement Bell Plugs
probably not what you want but I found these blind plugs on Amazon.
Startingover is online now   Reply With Quote
Old 02-26-2018, 07:09 AM   #3
Rewards Points: 7,799
The parts are not a proprietary item. They are simply a plastic plug and anything that fits the hole will work; even the ones from a $5 vinyl blind might. You might also find them in the specialty hardware aisle at Lowes or HD. There are 21 pages here: https://www.lowes.com/search?searchTerm=plastic+plugs Measures hole and then browse.
The only useful purpose they serve is that of holding the ladder cord tight and inside the channel. If the blinds are always down tape could save the same purpose.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Vinyl replacement windows First timer1 Building & Construction 6 04-30-2009 10:22 PM
Vinyl Replacement Windows fixiechick General DIY Discussions 56 04-20-2009 05:37 PM
Vinyl Window Replacement aschau01 General DIY Discussions 2 12-23-2008 05:17 PM
replacement vinyl window & door leaking adamc Building & Construction 7 09-09-2008 04:29 AM
