Wooden Staircase Issue - Flooring - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 10:46 AM   #1
Wooden staircase issue
So I recently installed wood floors and wanted to reuse the wooden railing & banister. I got help cutting the curve as close a possible, but I doesn't look that great. Any ideas on how to fix it?
I was thinking possible filling in the bigger holes with wood glue and smaller shims, then sand, and then stain, possibly add wood putty for the very small infractions. Any help / ideas?
Wooden staircase issue-imag1238-small-.jpg   Wooden staircase issue-imag1239-small-.jpg   Wooden staircase issue-imag1240-small-.jpg   Wooden staircase issue-imag1241-small-.jpg
smooth1_2u is offline   Reply With Quote
Old 03-20-2012, 10:59 AM   #2
Rewards Points: 18,374
No amount of filler or patching is going to hide those flaws.
Most of what I can see was just done wrong.
Rails are never attached to the balisters with screws at an angle like that instead there should have been installed with what's called a rail bolt.
http://www.stairsupplies.com/eng/pro...9600_rail_bolt
Looks like someone installed some screws without predrilling and counter sinking and split the wood.
Some of those miss fits should have been dry fitted and cut again until the angles were perfect.
Sorry but if you want it to look right it's a do over.
Old 03-20-2012, 11:11 AM   #3
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
You'll never get that fixed to the point that you can stain it and it will look good.
I would remove the damaged / ill fitting parts and make them again, then reinstall.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 03-24-2012, 03:44 PM   #4
Make friends with blind people? ::
MissKat is offline   Reply With Quote
Old 03-27-2012, 09:05 AM   #5
Crusty Old Dude
Big Stud's Avatar
You can fill it with wood and glue as you sai . Then paint faux grain lines to match the wood that is there. You need some artistic skills to pull it off, but I have seen it done with excellent results by artisans.
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 04-02-2012, 05:17 PM   #6
It's a do over.
You can use the craked pieces as a template for the new one. This way, you can correct the unsightly gaps. You need a rail bolt for the ballisters.
If you only drilled those srews in at the bottom of rails and they are all close to the bottm, you can cut off the very bottoms of the balisters to reuse.
Most people will never notice that your railing is an inch or so shorter, especially women and children.
Good luck taking it apart!
Janetp is offline   Reply With Quote
Old 04-03-2012, 01:58 AM   #7
I agree with Jane. Just redo it and you can use many of the pieces as templates for new ones. All the parts you need shouldn't be much more than a few hundred dollars which will be well worth it.
RhodesHardwood is offline   Reply With Quote
Old 04-03-2012, 02:51 PM   #8
StainlessRailGi's Avatar
agreed w the do over
Originally Posted by Janetp View Post
It's a do over.
I have to agree that this is definitely a do over....better to start from scratch and have it look 100% then try to bandaid it up.
stainless steel railing
StainlessRailGi is offline   Reply With Quote
Old 04-03-2012, 08:05 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 590
Not to bring more bad news but, those rails are not in code, the spindles are too far apart. That can be fixed but it isn't easy.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 04-04-2012, 01:48 AM   #10
Good eye Jim! I didn't spot that all. We all know this guy worked so hard on this, and I fee
l kinda bad to tell him it's a do-over, but this is something you see every day and cannot be hidden away. It's not like a bad paint job in a closet or missing baseshoe in a laundry. Chances are this is the first thing you see coming into the house.
E for effort! That is not an easy project to do by hand for someone with good skills.
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 07:16 PM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 08:20 PM
Wooden flooring and moisture content findlay70 Flooring 0 05-25-2011 01:03 AM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 09:19 AM
Trimming a staircase Richo Carpentry 38 09-30-2010 10:13 AM
