Wood Stairs And Wood Flooring Upstairs Hallway - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2015, 03:48 PM   #16
Rewards Points: 363
Photo of the high spot at the stair
titan7 is offline   Reply With Quote
Old 01-06-2015, 06:07 PM   #17
Rewards Points: 363
Got the 78" level out, from edge of landing to middle of the opposing door jam is 5ft, the floor is out 1 1/8" in this span. Two feet down the hall the slope is 7/8" off in 5 ft.
4 more ft down the hallway the slope is 3/8" out in span of 3.5 ft, it gets a little better as I measure further down the hallway. Wondering if that landing subfloor is high due to the riser being high on that last step or something else?
Old 01-06-2015, 06:27 PM   #18
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,678
Originally Posted by titan7 View Post
Thanks Jim, wow, what a mess!! I can't leave a 1.25"inch slope in 4-5 feet with wood flooring going down, that will look like crap, I can see the slope on the subfloor from the end of the hall, but I have bad OCD. So perhaps we split it so the slope is only 5/8" out, I figure at about half of what it currently is it won't be so visable. I think we could do that as the Garrison engineered floors are 9/16" high, and Carpet is going into the bedrooms.
What if I used a leveling compound or 3/8" plywood screwed to the subfloor to make up most of the low area and then use leveling compound or something like that to float from the edge of the 3/8" material to the subfloor? I guess we could use roofing felt or similar in the opposing bedroom entry to at least smooth the transition out?
I really don't want to go back to carpet for another 20+ years in the hall.
Thanks again for the help.
I really wish I had an easy answer to help you out but I don't, I am not sure the leveling compound will work on plywood decking. I suggest you make a new thread in the flooring forum and see what the pros have to suggest. I am sorry.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
new stairs and wood flooring Toni Prunty Remodeling 1 04-07-2014 12:59 PM
install wood flooring on stairs cfoush Flooring 4 08-18-2011 11:37 AM
Wood flooring and Stairs dsickler Flooring 6 04-14-2011 11:51 AM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 06:50 PM
Installing Hard wood in hallway with stairs basledder Flooring 1 11-03-2008 04:56 PM
