Wood Floor Install - Flooring - DIY Chatroom Home Improvement Forum
Old 12-29-2015, 06:36 PM   #1
Rewards Points: 22
Wood floor install
I'm redoing an attic and the daughter-in-law wants to put down a floating, interlocking wood floor. House is 60 years old with 3/4"x4" tongue and groove pine floor. I have enough sheets of 1/2"? OSB, that I used as flooring in the kneewall storage areas, to use as underlayment. But I see that people here mention 1/4" 'underlayment plywood'. Is that what I should be using? And I guess just a long enough nail to go through the T&G and into the joists? Thanks.
OldDIYer70 is offline   Reply With Quote
Old 12-29-2015, 06:40 PM   #2
griz's Avatar
Rewards Points: 572
Your 7/16" OSB will be great underlayment.
griz is offline   Reply With Quote
The Following User Says Thank You to griz For This Useful Post:
rusty baker (12-29-2015)
Old 01-01-2016, 05:41 PM   #3
Solutions (handyman)
Rewards Points: 488
The only issue with OSB is that sometimes the particles are uneven. (especially if they get wet). Most coverings will be safe but avoid Lino on OSB as it will show the uneven spots of OSB. Other than that, you should be fine.
Mark Harvey is offline   Reply With Quote
Old 01-02-2016, 11:38 PM   #4
Rewards Points: 22
Thanks for the reply Mark. I was thinking luan plywood as has been used in the past, but I read that it's use for that has been replaced by underlayment plywood. I went out today and picked up the UP I need to do the floor tomorrow. I'll make use of the OSB in most of my remaining knee wall areas for possible storage.
Bruce
Old 02-26-2016, 03:51 AM   #5
CNL woodflooring limited
Rewards Points: 2
During installation of wood flooring, the inner quality and installation method are significant. However, problems about paint, glue, underlayer, skirting are ignored. If these seemingly simple accessories are unsafe and unenvironmental-friendly, then they would influence the whole surroundings of the house.If the skirtings and buckles are unfit, the effects are not satisfactory even we have the best wood flooring. Therefore, when should not ignore the accessories and ingredients.
hardwood-timber is offline   Reply With Quote
Old 02-26-2016, 06:42 AM   #6
Retired Moderator
Rewards Points: 7,174
I could not have said it better!!!
Old 02-27-2016, 12:04 AM   #7
Registered User
Rewards Points: 526
Welcome to the forums!
https://www.google.com/search?q=+How...utf-8&oe=utf-8
Gary
Permanent Wood Foundation: Basment Questions!!! topdiggy2 Building & Construction 17 02-19-2016 10:10 PM
Question regarding bare wood behind top of gutter voodoochile Roofing/Siding 16 09-03-2015 04:00 PM
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
