Will A Few Days In A Row Of High Humidity Throw Off My Acclimation? - Flooring - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By ron45
  • 1 Post By chandler48
Old 06-01-2018, 11:19 AM   #1
Thumb smasher
Rewards Points: 32
Will a few days in a row of high humidity throw off my acclimation?
I've had 3/4" oak flooring in the house for a month now while I worked weekends to rip out and replace old flooring/subfloors, etc. Subflooring has been in the house for close to 2 weeks now already.
I left it in the cardboard but stickered it, figuring the circulation would help. I figured after a month I wouldn't have anything to worry about.
I am getting ready to finally lay it down, but the last 2 or 3 days has had rain and high humidity, but even though the A/C and dehumidifier's been cranking it's still been around 60%+ in here.
Do I have to worry about these few days throwing off the moisture content in the flooring?
I went out and bought a little moisture meter, but what do you know I don't get any readings on it for the flooring. Subfloor shows between 7 and 11, depending on where I stick it, but I am starting to think the meter is junk.
Does anyone have any thoughts other than "buy a good meter" which I can't seem to find in stores anywhere, other than ordering.
Thanks!
NatRussel is offline   Reply With Quote
Old 06-01-2018, 12:37 PM   #2
Rewards Points: 6,442
Re: Will a few days in a row of high humidity throw off my acclimation?
For accuracy, cut a sample a few inches from the end of a piece then use this - formula - for an accurate measure of moisture. About 3-4 Oz. of wood weighed on a postal scale, dried in the microwave not exceeding 200F, and dried until the sample ceases to loose weight.
Old 06-01-2018, 12:40 PM   #3
Rewards Points: 6,134
It acclimates to the house, not the outside.
ron45 is offline   Reply With Quote
Old 06-01-2018, 01:35 PM   #4
Thumb smasher
Rewards Points: 32
I realize this - the humidity of the house, at least as measured by my thermometer/weather station doohicky, has been reading high as well, thanks to the outside.
Everything I read says you should be 30-50% RH in the house, but damn if that seems really dry to me. It's been low to mid 50s for a few weeks, and I'm in northeastern NY, not like I'm on some coast line or down south somewhere.
Old 06-01-2018, 02:36 PM   #5
Rewards Points: 10,806
Seems really dry to me too. I know my home will not see 40% RH humidity until next January. It will never see 30%.
I put in some engineered flooring last year and tried to keep my home around 50% RH for the acclimation and install. Engineered is less sensitive to humidity changes, and I was told it did not matter, but I wanted humidity to be about halfway between winter and summer levels anyways.
But if all else fails, follow manufacturer's instructions.
I doubt a few days of rain will throw off the acclimation, but that is just my opinion. I have no way of backing up that statement.
SPS-1 is online now   Reply With Quote
Old 06-04-2018, 09:59 AM   #6
According to your thinking you will never get the floor installed.
Dave Sal and chandler48 like this.
Old 06-04-2018, 04:00 PM   #7
Naildriver
chandler48's Avatar
Rewards Points: 3,572
I agree with Ron45. So the humidity rises in the house? That is acclimation after the fact. It will happen. Then the humidity will lower. It's like a see saw, although it doesn't have as much swing as it would outside.
ron45 likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Tags
acclimate , hardwood
What size evaporative cooler? algeeba HVAC 9 03-05-2015 09:45 PM
High humidity in house in winter reddog General DIY Discussions 7 06-28-2011 05:38 PM
High humidity for how long????? timchi29 Remodeling 2 11-14-2008 06:43 PM
high humidity in basement orange HVAC 17 08-20-2008 01:24 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
