Why Does The Subfloor Have To Be Flat? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-29-2015, 09:27 PM   #16
Rewards Points: 996
post pics.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
JazMan (09-29-2015)
Old 09-29-2015, 10:14 PM   #17
Rewards Points: 51
OK- I checked the crawlspace. The joists are actually 4x6's, and they're sitting on concrete blocks ~6' apart. The plywood is actually 1 1/8" (not sure why I thought it was 3/4"). The plywood is in 4'x8' sheets, so why wouldn't they span 4'? Regardless, the plywood does appear to be attached directly to the joists.
Not sure what pix you'd like me to post at this point- the floor is all Frankensteined with these extra pieces of plywood, but here are some of the photos I took before I started messing with the floor:
You might notice the white mold on them and the water stains. Another reason why I was thinking I might want to replace them- though that's going to be pretty expensive, now that I know I've got to get 1 1/8" ply instead of 3/4". I did bleach them and air them out (and fixed the underlying problem, in case you were wondering), so I had hoped I could manage. And the problem with the flatness isn't because of board warpage, it appears to be more just because the joists aren't totally level to eachother. The individual boards themselves are flat, but there does appear to be a dip at one joist, and a rise at the next one.
Any help you guys can give me is totally appreciated
preciouschristy is offline   Reply With Quote
Old 09-30-2015, 05:46 AM   #18
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,524
It's a no brainer for me.
I would have had those boards ripped out and had the underlying problem fixed faster than all the messing around you did. It's easy to fix joists from the top with no sheathing in the way.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 09-30-2015, 10:02 AM   #19
Rewards Points: 54
They're 6' long, but how far apart are the spaced? If it's really 4x6s 4 feet apart, that ain't gonna cut it, even with a full 1" of plywood on top.
wetech is offline   Reply With Quote
Old 09-30-2015, 09:16 PM   #20
Rewards Points: 996
the joists, supports, attachments, foundation. in the crawl space.
looking at your floorboards shows us nothing.
Old 10-02-2015, 01:52 AM   #21
Rewards Points: 5,004
Are you sure they are spaced 6' apart.?
That would mean the plywood is either cut to 6' lengths, or runs parallel with the joist.?
ron45 is offline   Reply With Quote
Old 10-02-2015, 03:00 AM   #22
Rewards Points: 51
Hey guys-
Thanks for all the help, but I think at this point, I'll consult (or hire) someone here who knows the local codes- I appreciate all the advice, but I just feel like it's getting too difficult to explain, especially when it seems like things are so different in different regions. This might have been too big a project for me to tackle alone-
Old 10-02-2015, 03:43 AM   #23
Rewards Points: 6
Pics, or a sketch, would help. . And a location ; there might be a local member from here that might point you in the right direction.
asevereid is offline   Reply With Quote
Tags
flat , level , subfloor
Smooth walls with flat paint...looks weird to me? TOTALN00B Painting 3 04-25-2011 06:42 AM
will a flat roof always leak............. cappuccino Roofing/Siding 6 04-19-2011 05:16 PM
Flat paint help in apartment cnj419 Painting 4 02-24-2011 08:07 PM
Using Flat Paint on Flat Paint that had been touched up with Gloss! Russell_Case Painting 1 01-17-2009 07:58 PM
