Where To Position Wood-carpet Divider At Door - Flooring - DIY Chatroom Home Improvement Forum
Old 09-08-2014, 04:41 PM   #1
Rewards Points: 1,062
Where to position wood-carpet divider at door
I am puzzled where to position the divider between hardwood and carpet at a bedroom door. Please see the picture. There is existing carpet on the left and on the right is a hallway that will have hardwood flooring. The hallway also used to have carpet but I got rid of it. I thought the best would be if the divider is exactly under the door when it's closed. Are there general guidelines or a rule of thumb how to divide the two floor coverings at a door?
Where to position wood-carpet divider at door-forumrunner_20140908_164142.jpg
Old 09-08-2014, 05:14 PM   #2
For this simple question you do not even need a picture. Get over yourselves, you're not fixing an airplane.
The Following 2 Users Say Thank You to amakarevic For This Useful Post:
Fix'n it (09-08-2014), gregzoll (09-08-2014)
Old 09-08-2014, 06:37 PM   #3
Originally Posted by JazMan View Post
So, do you now know where to put the molding??
No...
Old 09-08-2014, 10:05 PM   #4
Rewards Points: 582
hey guys lighten up...no need to be rude...
Old 09-08-2014, 10:14 PM   #5
Rewards Points: 996
yeah. i think they both over reacted. call it a wash, and move on.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 09-08-2014, 10:15 PM   #6
Rewards Points: 996
oh. the transition goes under the closed door.
The Following 2 Users Say Thank You to Fix'n it For This Useful Post:
amakarevic (09-08-2014), ben's plumbing (09-08-2014)
Old 09-08-2014, 10:18 PM   #7
Thanks for the succinct answer
Last edited by TheEplumber; 09-08-2014 at 10:58 PM. Reason: unnecessary comment removed
Old 09-08-2014, 10:47 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 948
Rude or unnecessary comments removed
Old 09-08-2014, 10:51 PM   #9
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 396
You didn't remove his rude comments.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Old 09-10-2014, 02:04 AM   #10
Jello Wrangler
Rewards Points: 539
Transition under the door. That way you see only wood on one side and carpet on the other.
ChiTownPro is offline   Reply With Quote
The Following User Says Thank You to ChiTownPro For This Useful Post:
amakarevic (09-11-2014)
Rotten wood under threshold of patio door [email protected] Building & Construction 13 08-28-2014 07:22 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 07:50 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 09:16 PM
