When Do I Lay Baseboard - Flooring - DIY Chatroom Home Improvement Forum
Old 03-25-2014, 10:51 PM   #1
When do I lay Baseboard
Im redoing my bathroom.. I was originally going to leave the baseboards, put
down the underlay 1/2 inch ply, tile and put some shoe molding.
Something then told me to rip the nice baseboards out that were already there.
Im wondering now when I put the new baseboards in. On top of the plywood?
On top of the tiles? In between the tiles and wall? I really have on idea. Can
someone please explain..
thenameisdame is offline   Reply With Quote
Old 03-25-2014, 11:54 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
On top of the tiles. Welcome to the Forum.
iminaquagmire is offline   Reply With Quote
Old 03-26-2014, 01:59 AM   #3
Rewards Points: 6,652
After you are done putting down the floor, painting the walls, putting in the vanity and any other cabinets, and after the door trim is up.
Make sure after you tile, that gap that is between the tile and the wall. Make sure you caulk that area, so no water seeps down in there, in case someone decides to leave the shower curtain open, or the toilet overflows. Also make sure that you caulk between the tub and tile also. Same goes for where the tile meets the closet flange.
If you put up a tiled surround, make sure that you caulked between the tile and the tub, and also the vertical corners.
Baseboard. A Big Deal Question! altc81 Flooring 15 11-03-2013 04:00 PM
Rotted Baseboard miamicuse Carpentry 11 09-08-2013 10:09 AM
Electric Baseboard Convection Heater - Buying House Info? olimits7 HVAC 4 10-24-2012 10:45 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
