What To Put Under The Waterproofing Membrane. - Flooring - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 12:43 PM   #1
What to put under the waterproofing membrane.
Hey
I have this question stuck in my head. What kind of adhesive do you use to make the waterproofing membrane for tiling to stick onto the floor.
TurboDIYer is offline   Reply With Quote
Old 01-21-2012, 01:34 PM   #2
Retired Moderator
Rewards Points: 7,174
Check with the maker---modified thinset is used by most--one maker only wants unmodified under their brand--
Let us know the exact product you are considering and someone here should be able to help.
Old 01-21-2012, 01:57 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 780
Turbo,
It's not clear what it is you're doing, please xplain. By the title I first thought you're building a shower or something that requires waterproofing. Mike thinks in another direction.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (01-21-2012)
Old 01-22-2012, 12:21 PM   #4
I'm wanting to tile up the floors on my powder room and from me watching some Holmes on Holmes and Disaster DIY, they use a water-proofing membrane on the washroom floors. They just dont say what adhesive they use to stick the membrane on the floor.
Old 01-22-2012, 12:35 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
I think they place the membrane in the bed of thinset on the shows.
Sounds like your making a wetbed
Dont forget if you have a doorway to the room you need to install a saddle as well.
JetSwet is offline   Reply With Quote
Old 01-22-2012, 12:35 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 780
They use a lot of Ditra uncoupling membrane, which can also be used to (somewhat), waterproof, a floor. You install it using a 'substrate-appropriate" thinset. Over ply you'd have to use a modified/polymer mortar, over concrete they recommend unmodified. Ditra is orange in color and has a waffle looking surface.
Note that simply using Ditra does not completely waterproof the room. You'd have to flash it up the wall and build a curb in the doorway like a shower to make it waterproof. However it will protect most of the subfloor under Ditra. Its main function is to uncouple the floor from the tile work so nothing bad happen when the floor shrinks and expands.
Floors do not require special waterproofing, but Ditra is a great product that does a good job.
Sounds like you're making a wetbed
I don't get that impression at all. What makes you think Turbo is planning the 1" or thicker mud bed?
Jaz
Old 01-22-2012, 01:06 PM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
Because he wants to use ditra or what turbo is describing as so like as seen on tv and like you have described to go up the wall that's the only time I have seen this done when using such membrane but not how much mud filler used?...
Old 01-22-2012, 03:14 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 780
Turbo is a DIY'r and I've never seen Holmes mention or do a mud-job. It's not an installation method you'll see many DIY'rs attempt, for good reason. Turbo just wants to tile a powder room himself.
Turbo, tell us about the subfloor and your plans.
Jaz
Old 01-22-2012, 03:48 PM   #9
Pro
JetSwet's Avatar
Rewards Points: 502
Jaz
Sorry JazMan I think I just misunderstood your prior reply.
Old 01-23-2012, 05:12 PM   #10
First of all, how about you guys just call my Jay cause being called Turbo isn't really the greatest name.
Yes, I am planing to use a Ditra as a membrane on my powder room floor with ceramic tiles. The sub floor is 3/4 inches thick and I haven't demo my old tiles yet but I will start soon. Could you guys provide me with a shopping list for what to buy even though I live right beside HD.
Old 01-23-2012, 07:51 PM   #11
Pro
JetSwet's Avatar
Rewards Points: 502
Ok Jay, so you are leaving the subfloor there just taking tile out? How positive are you that you have 3/4 worth of subfloor?
Old 01-23-2012, 10:03 PM   #12
This is a house was bought as a blueprint. I have been involved in every process of my house being built.
Old 01-24-2012, 01:38 PM   #13
Pro
JetSwet's Avatar
Rewards Points: 502
If you only have 3/4 of ply in your floor you will need to add 1/2 you need at least 1" of wood for proper tile install ditra or cement board it not for a structure sound floor.
Old 01-26-2012, 09:16 PM   #14
Do I have to do that?
Old 01-26-2012, 10:23 PM   #15
Tileguy
JazMan's Avatar
Rewards Points: 780
HUH? Where did you get that? Please let us know.
Jaz
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Why I can't use thin-set mortar over RedGard waterproofing membrane? sukhenkoi Kitchen & Bath Remodeling 9 03-16-2013 03:39 PM
Torch on roof membrane on deck canada55 Roofing/Siding 36 03-03-2011 03:18 PM
Delta waterproofing membrane RINAIL Building & Construction 2 03-30-2008 10:52 AM
