What Options On Slab Floor? - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By SeniorSitizen
  • 1 Post By Nealtw
Old 02-12-2018, 06:53 PM   #1
Rewards Points: 64
What options on slab floor?
My daughter has a town home that has some type of stick on fake looking wood floor. It is actually shrinking length-wise to where 1-2" gaps are visible.
What are the best options for replacement? Engineered hardwood? And is this glued down? I'm assuming I'll have to remove the existing.
I have experience installing 3/4" hardwood floors with a nailer but nothing on concrete slabs.
Thanks Rut.
rutledj is offline   Reply With Quote
Old 02-12-2018, 07:12 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,244
Re: What options on slab floor?
You can float it or do a glue down.
For a glue down.. yes remove it..
If the sub is adheared well... I think you could float it.
MTN REMODEL LLC is online now   Reply With Quote
Old 02-12-2018, 07:16 PM   #3
Rewards Points: 1,506
We've had vinyl for about a long time and for appearance, wear, maintenance and cost wouldn't consider anything else on those areas that require something other than carpet. Options are nearly infinite.
Nealtw likes this.
Old 02-12-2018, 08:15 PM   #4
Rewards Points: 17,912
Tile, or vinyl planks would also work.
Old 02-12-2018, 08:26 PM   #5
retired framer
Rewards Points: 20,386
After trying a bunch of what I would call crap o the market today. I would go back sheet lino. It never gave us trouble and would easily last until the styles changed.
SeniorSitizen likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
skordish (02-21-2018)
Old 02-13-2018, 04:33 PM   #6
Rewards Points: 1,042
Engineered flooring is the way to go, i have some down for about 9 years and it looks like the day i installed it, here's a link that may help you decide, i installed mine floating.
https://www.hoskinghardwood.com/Depa...dId=7&pageId=7
Canarywood1 is offline   Reply With Quote
Replacing Garden Tub w/Tile Shower on a Slab floor.. Need Help!! cufflinks General DIY Discussions 16 05-20-2013 06:16 AM
Second floor joists are horribly undersized.....options? jerseyguy1996 Building & Construction 36 06-22-2012 12:20 AM
Insulating Split-Level Ground Floor Concrete Slab illusion8055 Building & Construction 7 03-02-2011 08:26 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Bathroom 'wet floor' - floor slope options Couch Plumbing 9 03-11-2008 04:42 PM
