What Flooring Is Best For Cold Climates? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-29-2014, 12:37 PM   #1
Rewards Points: 155
What flooring is best for cold climates?
Will just be heating on weekends in winter, so a floor that can withstand drastic temp changes varying from -40 to 70, without cracking or warping. My first guess is a sheet of vinyl, floated not glued?
wilyum is offline   Reply With Quote
Old 03-29-2014, 02:42 PM   #2
Rewards Points: 7,194
That's what I would install no matter what the climate but if you haven't done so you might consider checking with a manufacturer for the cold conditions.
Old 03-29-2014, 03:18 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,002
Vinyl will probably be Ok, as long as you stay off of it during the extreme cold.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-29-2014, 05:50 PM   #4
Rewards Points: 155
Great heating will be on a timer before arrival, so that wont be an issue.
Old 03-29-2014, 08:53 PM   #5
msaeger's Avatar
Rewards Points: 260
How about carpet?
msaeger is offline   Reply With Quote
Old 03-29-2014, 09:46 PM   #6
I would think that carpet would work, too.
Old 03-30-2014, 04:10 PM   #7
Rewards Points: 155
Does anyone know a company that makes 20' vinyl sheets? the box stores only seem to sell 12' at the max.
Old 04-08-2014, 06:39 AM   #8
13' 3" (3 meters) is as wide as you can get. Years back, there was some 15'.
Old 04-08-2014, 09:04 AM   #9
Rewards Points: 135
Vinyl works, as Rusty says, if you stay off it when cold. We have to go to our place to put on the heat, so we went with an interlocking laminate product (Terraco tile?) in the bedroom, Snapstone tile in the bath and kitchen, and pine plank in the great room. So far so good.
ptarmigan61 is offline   Reply With Quote
Old House Flooring Installation Advice rsvedin Flooring 2 03-15-2014 07:12 AM
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-18-2012 11:51 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
