What Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SeniorSitizen
Old 10-14-2018, 09:35 AM   #1
Rewards Points: 90
What flooring?
So I see a lot of hatred to laminate flooring on here, so my question for you is:
If someone needed new flooring, do not want carpet, have pets so have to be scratch resistant, and roughly trying to spend a $3-$4 sq foot. Oh yea no tile because they donít like the feeling.
EWC88 is offline   Reply With Quote
Old 10-14-2018, 09:37 AM   #2
Guapo
Rewards Points: 11,950
Re: What flooring?
Rubberized flooring. Google it.
Guap0_ is offline   Reply With Quote
Old 10-14-2018, 09:48 AM   #3
Rewards Points: 5,658
Re: What flooring?
For durability and ease of maintenance sheet vinyl is all that would be on the hard surface in our house. Resale, don't make me laugh. The new owners can install whatever they like.
Nealtw likes this.
Old 10-14-2018, 11:53 AM   #4
Rewards Points: 10,458
Re: What flooring?
Engineered hardwood. The bottom is basically plywood, so it does not expand/contract with humidity much (or at all). If you are buying less expensive flooring, check the specs on the finish --- seems its pretty common today for any half decent engineered to have six or more coats of UV cured urethane on top with upper layer with aluminum oxide dust for good scratch resistance. One note on price --- cheaper engineered hardwood will have lots of short pieces, better quality hardwood gets you longer pieces (longer pieces look better IMHO).
SPS-1 is online now   Reply With Quote
Old 10-14-2018, 12:00 PM   #5
Rewards Points: 1,228
Re: What flooring?
Vinyl plank aka LVT. Goes in like laminate but solid vinyl so it wear much better and is impervious to water. Easy DIY install. In a bathroom I'd use sheet vinyl.
Marson is online now   Reply With Quote
Old 10-15-2018, 06:33 PM   #6
Rewards Points: 90
Re: What flooring?
Will be checking all the options out. Vinyl probably wonít go cause someone (gf) isnít a fan of it.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
removing laminate flooring mikeinMemphis Flooring 24 02-24-2013 09:06 PM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 12:21 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
