What Do I Use To Cut Engineered Flooring? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-29-2015, 11:20 AM   #16
Rewards Points: 76
Originally Posted by JazMan View Post
So how you gonna finish these new unfinished planks? To make it all blend you have to sand, stain and apply a finish to the entire job......NO?
Jaz
Lots of trials and errors
Originally Posted by Eddie13 View Post
Maybe you should just put the fireplace back.... Or is it too late?
I'd rather have a hole in the floor than have that fireplace again lol I hate it
pl4eva is offline   Reply With Quote
Old 04-30-2015, 11:01 AM   #17
Rewards Points: 6
I think you can try one time Rubber Tiles
MikelH is offline   Reply With Quote
Old 04-30-2015, 12:52 PM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 716
As far as matching stains and matching poly finishes..... I run into the issue alot with repairing flip properties.
It's not rocket science.... just trial and error. Get several close stains and experiment... you may have to mix several..... use scrap flooring pieces.
Then also pay attention to your poly finish..... clearness or amber affect will be different among brands, and sheen will vary even with the same name (flat/satin/semi).
As you are just doing small sample sections, you can probably return your non-used product if you are clean with it.
I'm usually able to come very close.
Good luck
MTN REMODEL LLC is online now   Reply With Quote
"accent/border" strips with engineered flooring Brown Dog Flooring 0 10-10-2012 07:32 PM
engineered wood flooring nailer joshanah Flooring 3 06-04-2012 12:21 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
engineered wood flooring flugalbinder Flooring 1 05-06-2009 11:51 AM
Engineered Flooring Install Question funktional Flooring 2 01-04-2008 04:45 PM
