What Do I Need For A Sub Floor On Concrete To Lay Ceramic Tile. - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-20-2014, 07:43 PM   #16
Retired Moderator
Rewards Points: 7,174
Proper layout helps you avoid ugly,narrow cuts---a chalk line and a ruler , a framing square and some common sense--(and hair spray to keep the lines from getting wiped off)
we will walk you through that,if you wish---
Tile Help (06-22-2014)
Old 06-22-2014, 05:29 PM   #17
Hello, I am new to DIY and am learning my way around while tending to a spouse that just had surgery, I am also seeking employment since my contracted ended after 9 years. I, sincerely, thank every one for all their patience and advice for me.
Tile Help is offline   Reply With Quote
Old 06-22-2014, 06:27 PM   #18
Retired Moderator
Everyone here is glad to help----when you have more questions--ask away.--Mike---
Old 06-22-2014, 07:49 PM   #19
Super Moderator
Gymschu's Avatar
Rewards Points: 380
I'm a lowly painter and I have tiled a basement with success. So, yes, you can do it. It's hard on the knees and you will be tested by how well you laid things out, but don't be dismayed, it IS doable.
The Following User Says Thank You to Gymschu For This Useful Post:
oh'mike (06-28-2014)
Tags
tile sub flooring
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 09:56 AM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
ceramic tile over fresh concrete question brewcrew Tiling, ceramics, marble 26 08-28-2011 10:38 PM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
