Water Got Through Concrete Sealer Cracks When Cleaning, Leaving Dark Spots - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2018, 04:03 PM   #1
Rewards Points: 4
Water got through concrete sealer cracks when cleaning, leaving dark spots
Hello,
I was sealing my concrete floor with water based poly. I was going to apply 3 coats, but after 2 coat I decided to clean the floor with lukewarm water as there was some dirt on the floor.
After I applied water, I saw that there were some dark water spots around cracks and small holes. Most of them disappeared after couple of minutes, except for one spot where I left the water bucket (which was there for couple of hours). It looks like the water has gone through the poly and under it, I've been waiting for 2 days and the water doesn't evaporate.
The poly had already been cured for 2 weeks.
I've tried using a hair dryer for about an hour, but it didn't change a thing.
Also, where I live, humidity shouldn't be a problem. Its around 60%.
What can I do? Is this permanent?
atlii is offline   Reply With Quote
Tags
concrete floor , concrete sealer , polyurethane
Water got through poly cracks when cleaning, leaving dark spots atlii Concrete, Stone & Masonry 2 05-10-2018 12:42 PM
2nd Floor Bathroom Leak KenOhio76 Plumbing 7 01-09-2018 02:10 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
