Vinyl Tile Over Old Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 04-15-2014, 08:32 AM   #1
Telescopist's Avatar
Rewards Points: 91
Vinyl tile over old tile
I have an apartment that I am rehabbing. The upstairs comprised of 2 BR & hallway were tiled ages ago. The tile is worn out. There are a few pieces or chunks missing otherwise it appears to be firmly attached to the floor. I'd like to put down a new layer of vinyl tile over the old. 1. Is it feasible? 2. If so, what preparatory steps would I be advised to take before doing this? I could ask these questions in the flooring dept. at a box store. However, half the time they don't really know what they are talking about. Thanks in advance for suggestions.
Telescopist is offline   Reply With Quote
Old 04-15-2014, 09:38 AM   #2
Rewards Points: 304
You can but you would have to lay down plywood underlayment first. I would just install carpet or hardwood laminate.
JustinK is offline   Reply With Quote
Old 04-15-2014, 09:51 AM   #3
Rewards Points: 91
I have been thinking much the same actually. The hardwood laminate would be a better upgrade too. Never have installed hardwood laminate. How is it installed. Glue? Pneumatic nailer? Thanks.
Old 04-15-2014, 10:02 AM   #4
Rewards Points: 19,142
What type tile is on the floor now?
Tile could mean a lot of different things.
No such thing as hardwood laminate.
There's laminate that's just a picture of real wood laid over anything thing from particle board, fiberboard ECT. It's a floating, no glue, no nails.
Should never be used anyplace there's a chance of water getting on it!
Engineered flooring is real wood veneer over plywood or some other substrate. It's nailed, glued or with some styles can even be a floating floor.
Old 04-15-2014, 10:47 AM   #5
Rewards Points: 91
Need lowest price solution. This is a rental. No chance of a water problem. All rooms contain old Armstrong tile. Adhesive hasn't failed.
Old 04-15-2014, 10:59 AM   #6
Rob
Robpo's Avatar
Rewards Points: 826
I would try to see if self leveling cement will stick or just fill in holes with thin set and put vinyl over it.
Robpo is offline   Reply With Quote
Old 04-15-2014, 12:16 PM   #7
Rewards Points: 91
Sure. Originally this was sort of my 'plan'. Then JustinK responded by saying I would need to lay down a plywood underlayment. I think that would be a huge pain wrestling with a bunch of sheets of plywood dragging them up a winding staircase to a 3rd floor space. You are suggesting by contrast that with a little bit of prep work I could successfully apply a second generation of vinyl over the first without laying down the plywood?
Old 04-15-2014, 12:39 PM   #8
Rob
Robpo's Avatar
Rewards Points: 826
Sure. Older homes (40s) used a tar like glue to hold down linoleum which was too difficult to remove so you had to go right over them. Newer homes it is easier to remove the vinyl and patch any bad spots with a top and bond on the wood and then put new floor. If your floor doesn't come up easy I would use a top and bond to fill any voids and go right over it. If the top and bond doesn't stick to the tile then I would use thin set, it sticks to just about anything. First I would see if the old floor comes up easy.
Old 04-15-2014, 04:54 PM   #9
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,016
I would not remove the old tile. It and the adhesive could both contain asbestos. I would use a cementitious based floor filler to fill any holes, use a wax remover to clean the floor and tile over the tile.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Vinyl on Vinyl on Tile on Concrete blau808 Flooring 2 03-15-2013 10:55 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Vinyl sheet tile install - remove or level ceramic? Craigkapo Tiling, ceramics, marble 3 01-21-2012 01:13 AM
Removing vinyl tile (at least I think it's some sort of vinyl) natecase13 Flooring 1 07-13-2010 10:55 AM
Old flooring / installing new vinyl tile gwelton Flooring 2 06-24-2009 03:10 AM
