Vinyl Floor Tiles For Kitchen? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-27-2017, 07:07 PM   #1
Rewards Points: 2
Question
Vinyl Floor tiles for kitchen?
My grandparents want a new kitchen floor. They have old vinyl tiles which are separated and some are damaged. They want me to install a new cheap and easy floor. Their kitchen is really small also. Can I lay new peel and stick vinyl tiles on top or should I remove the old flooring? Are vinyl peel and stick a good choice here? Ive installed laminate before but its been a while. any tips or recommendations are greatly appreciated!
tfisch25 is offline   Reply With Quote
Old 03-01-2017, 12:01 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,650
Re: Vinyl Floor tiles for kitchen?
Peel and stick is never a good idea.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-01-2017, 01:13 PM   #3
Breakin' Stuff
Rewards Points: 1,360
Peel and stick will be cheap and easy, but it's definitely not what I would consider a quality product. You could take it a half step further and get the groutable kind. Being a kitchen you aren't going to want any cracks between the tiles for spills to creep into.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 03-31-2017, 10:47 AM   #4
Eddy88's Avatar
Rewards Points: 6
Thumbs up
Hi,
I had laminate floor before in my kitchen. Two months ago I installed vinyl tiles OVER the old floor and I didn't encounter problems since this day. It looks like paving, and we really appreciate it.
Keep me informed !
Eddy
Eddy88 is offline   Reply With Quote
Old 03-31-2017, 10:48 AM   #5
Eddy88's Avatar
Rewards Points: 6
I'f you're interested, it looks like this :
(image source : http://lebonpeintre.pro/sol-vinyle/)
Good luck
Old 04-01-2017, 12:08 AM   #6
Rewards Points: 16
It will never be a good idea to just peel and stick vinyl tiles on some areas that needs attention. Since you mentioned that vinyl floor tiles in there were already old then I suggest why not remove the old flooring and install new ones.
kathmorgan12 is offline   Reply With Quote
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
