Urethane Glue Adhesive - Flooring - DIY Chatroom Home Improvement Forum
Old 02-18-2014, 03:56 PM   #1
urethane glue adhesive
This past weekened ripped up Engineered Hardwood from concrete subfloor. There must of been a sale on Urethane glue when installed cause they used it on every single inch of +300 sqft. Not all the glue came up with the floor scraper though. Getting ready to put a floating bamboo floor down and using an foam underlayment with moisture barrier film. Have some SLC spots that need to be fixed from the use of the floor scraper but 2 questions.
1) does all the glue need to be removed?
2) What is the best way of doing this?
Petal1127 is offline   Reply With Quote
Old 02-19-2014, 11:07 AM   #2
As long as it's all true, shouldn't be a problem. Make sure you buy a good mat to avoid clicks and a better feel.
Mross91 is offline   Reply With Quote
What Adhesive to glue Tiles over Brick? cody21 Building & Construction 1 10-23-2012 03:27 PM
Carpet over adhesive glue Roses Flooring 1 05-25-2012 10:30 PM
Bathroom wall tile adhesive: Thin-set mortar or OmniGrip glue? novice10 General DIY Discussions 11 01-02-2012 05:46 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 08:54 AM
