Uneven Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-14-2013, 09:02 PM   #1
Rewards Points: 996
uneven floor
i just found out that my new kitchen subfloor is 1/4" lower. this room was an addition, and they used 1/2" planks. rest of the house is 3/4".
so, i need to raise it 1/4". what should i use ? i am thinking plywood, but idk. thats why i am asking.
thanx
Fix'n it is offline   Reply With Quote
Old 10-14-2013, 10:41 PM   #2
Rewards Points: 18,384
What's the plan for flooring.
Just 1/2 is not thick enough for any type of flooring, should have been at least 3/4.
1/4" is not going to add any strength.
Old 10-14-2013, 11:03 PM   #3
Rewards Points: 996
i think i would like tile, but idk if i will make the joists strong enough. so, as it is now, idk what flooring will be going in, WHEN that time comes. i am sistering joists now, but idk if they will make the floor tile worthy.
it has its original 1/2" planks. i put 1/2" osb over that. i would have put 3/4" had i known. but things were hidden.
the 1/4" would only be to bring the floor flat with the rest of the house.
Old 10-14-2013, 11:22 PM   #4
1/4 plywood can not be used under tile.
How did you attach that OSB?
Old 10-15-2013, 08:20 PM   #5
Rewards Points: 996
yeah, i know no wood should be under tile.
screws, a bunch of them. its is working out well. as we have been walking the the same in other parts of the house with no issues.
Old 10-16-2013, 09:33 AM   #6
Fix'n it,
Tile standards call for a minimum 3/4" exterior grade 'C' or higher for tile. I would tear out the 1/2" and replace it with at least 3/4". Now is the time to fix the floor. Your putting together a nice kitchen don't shortcut on the structure.
If your floor is not level now, take the top layer of 1/2" off and when you sister the joist make it level.
NASCAR9 is offline   Reply With Quote
The Following User Says Thank You to NASCAR9 For This Useful Post:
joecaption (10-16-2013)
Old 10-16-2013, 08:53 PM   #7
Rewards Points: 996
what if i left it. flattened it out, and put durock ?
Old 10-16-2013, 10:42 PM   #8
Fix'n it,
If you think you'll tile you should level from the bottom to the top. You can make up a little with thin set, but don't try and make up more than 3/16".
Lookup 'tile lippage' and you'll see what a floor looks like that is not level.
I feel your pain, my bathroom was 3/4" out of level in 5 feet.
Old 10-17-2013, 09:41 PM   #9
Rewards Points: 996
i am going to check the floor thoroughly this weekend. and go from there. if i can't do tile, so be it. i check the floor half assed, and it looked to be about 1/2" in 12'. so we will see.
Old 10-21-2013, 10:32 AM   #10
Rewards Points: 996
ok, got it figured out. the floor is basicly flat & level. except for 5' where it angles down to the back wall, 1/2". so i put a piece of 1/2" osb and the the cabinets back. i got it all pretty leveled out. so i will take the cabinets back out, screw down my boards. then installed the cabinets.
my issue now = tapered from 1/2" down to 0"ish in 3' . any ideas ?
Old 10-21-2013, 10:37 AM   #11
Rewards Points: 996
kinda hard to see. but there ya go.
Old 10-21-2013, 11:57 AM   #12
Is the floor flat and level? I can't tell if you have gaps under the level.
I'm sure you know that OSB is not rated for tile. It will delaminate when it gets wet.
Old 10-21-2013, 09:44 PM   #13
Rewards Points: 996
see the left handle on the level, its touching the floor right there. the other end is on 1/2 osb. 3' that i need to fill. so that when i do whatever flooring, its basicly flat.
i am going to look into those vinyl tiles, they don't need grout, but can use grout.
but really, i am probably going to do some kind of wood.
Old 10-21-2013, 10:39 PM   #14
If your going to do a laminate of some sort or vinyl tiles, you could use self leveling concrete to fill the low spot. I don't know if you would be able to nail hardwood through the concrete.
Old 10-21-2013, 10:54 PM   #15
Rewards Points: 996
yeah, i was thinking that. but didn't know if it would be ok over the osb. i suppose i could paint the osb first. i am also thinking thin layers of thin set.
Installing vinyl plank over existing, uneven floor? AKCDIY Flooring 5 11-01-2014 05:48 PM
Tiling kitchen. Floor uneven. Going crazy! allfy16 Tiling, ceramics, marble 1 10-20-2012 07:01 AM
Uneven floor and joists in new room Orangeclawhamme Building & Construction 35 11-16-2011 11:57 AM
Uneven floor dpreznik Flooring 7 10-11-2011 12:22 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 09:07 AM
