Underlayment To Replace 5/8 Particle Board - Flooring - DIY Chatroom Home Improvement Forum
Old 07-09-2015, 10:50 PM   #1
Rewards Points: 12
Underlayment to replace 5/8 particle board
I am remodeling the kitchen in a 40 yr old house we are moving into.
Currently has 5/8 4 ply sheeting grade plywood subfloor. in great shape. 5/8 particle board underlayment, sheet vinyl flooring.
I plan to go back with a good quality sheet vinyl again.
I HATE particle board. It has caused problems in our current home any time the inevitable leak occurs.
SO, I removed the baseboard and cabinets (getting new cabinets) and took up all the 5/8 particle board in the kitchen and breakfast nook.
Now I need replace it with something with good moisture resistance.
Staying with 5/8 would be good to match the other joining floors. I could do 3/4 as well if it added any positive value to the final results.
So, what to use?
TD
cparktd is offline   Reply With Quote
Old 07-09-2015, 11:14 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,644
You could go back with 5/8 plywood and 1/4" underlayment grade ply on top of it to give a smooth floor for vinyl.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 07-10-2015, 07:51 AM   #3
Rewards Points: 17,912
Make sure that plywood is subfloor rated.
It will be exterier glued and all voids filled.
NO LOUON plywood for underlayment!!
When laying the underlayment make sure the seams do not line up with the seams below, do not use any glue, needs to be attached every 4" on the edges, 6 to 8" in the field.
The fastest easiest way to do it by far is with a narrow crown pneumatic staple gun.
That way you do not have to go back and fill all the hammer damage.
All seams and flaws need to be filled with non gypsm filler.
Old 07-10-2015, 09:38 AM   #4
Rewards Points: 12
Would this be good?
BC 5/8. suitable for underlayment it says.
http://m.homedepot.com/p/19-32-in-or...135/100007300/
I understand about offsetting the seams from the ones in the subfloor and also the fastener density. I was planning on screws but could look into renting a stapler...
It had 15lb felt under the particle board before. Should I do that or something else again? Or is it even necessary?
Can you recomend a specific filler. Years ago I had trouble with some discoloration on a floor using Rock Hard putty under some cheap vinyl to fill a couple defects.
TD
Old 07-10-2015, 02:58 PM   #5
No need for felt.
DO not use screws it will leave humps.
8D ring shanks for the subfloor.
If you have a compressor buy a stapler instead of renting. You can buy a cheap one for less then $50.00. Only needs a small compressor to run it.
http://www.homedepot.com/s/narro%252...2520gun?NCNI-5
That plywood will work.
Old 07-10-2015, 03:26 PM   #6
Rewards Points: 12
Thanks all!
Yes I have a compressor.
Nailing hardwoods into particle board on top of plywood hejduk01 Flooring 2 12-02-2013 06:29 PM
Best way to remove old vinyl's backing from particle board underlayment richapple Flooring 9 11-11-2013 05:07 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Particle board underlayment help diynut Flooring 5 03-07-2006 05:22 AM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 08:32 PM
