Underlayment Question - Flooring - DIY Chatroom Home Improvement Forum
Old 06-24-2014, 01:40 PM   #1
Telescopist's Avatar
Rewards Points: 91
I have an apartment building with a small 15 square foot foyer. I removed the disintegrating carpet and what was underneath it. I just purchased 1/4" premium prime for new underlayment. I will be installing commercial grade vinyl 12x12 squares using the correct adhesive that works with it. I don't have a pneumatic gun that shoots staples so will have to use ring shank nails. I have two questions. 1. Should I apply liquid nail to the plywood when I fasten it to the floor? 2. Can I simply cover the ring shank nails with the adhesive and lay the tile or will I have to prep the nails with a filler first? Thanks.
Telescopist is offline   Reply With Quote
Old 06-24-2014, 01:47 PM   #2
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
you are putting 1/4" plywood under the new floor? What is it going on top of?
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 06-24-2014, 01:55 PM   #3
Rewards Points: 91
The plywood is going over an old wood floor. What used to be there was an underlayment of some sort and carpet. What will be going over the plywood (new underlayment) is 12x12 commercial grade vinyl squares.
Old 06-24-2014, 02:12 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 2,064
No glue under. Prep the nail holes. Nails should be every 2" along the edges, every 4" in the field.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 06-25-2014, 06:36 AM   #5
Rewards Points: 91
Thanks for that. This plywood I got has a bunch of X marks set out in a grid pattern. In the meantime, I decided to spend the money and save the time. I purchased a Porter Cable narrow gauge stapler. I've got a lot of flooring coming up in another building.
Old 06-25-2014, 12:46 PM   #6
The stapler makes sense.
Laminate with foam pad on top of underlayment? aidan80 Flooring 2 03-04-2014 08:46 PM
Underlayment removal around toilet donmigga83 Flooring 1 03-23-2011 10:48 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 02:24 AM
5V crimp metal roof underlayment question ugabulldog Roofing/Siding 1 06-21-2008 01:22 AM
