Underlayment Materials For Vinyl Sheet Flooring In Bathroom - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-10-2013, 06:12 AM   #16
After some chats with Lowes folks they suggested - as you did - to use the self leveling compound first.
which I did - and it worked well!
very pleased
djsted is offline   Reply With Quote
The Following User Says Thank You to djsted For This Useful Post:
oh'mike (12-10-2013)
Old 12-10-2013, 06:36 AM   #17
Rewards Points: 17,912
Not sure about anyone else, but if I had a buddy, or relative that was insisting on using something I know would not work I'd leave and do nothing.
Funny how when it fails they quickly forget it was there idea to do it that way and your going to get blamed for it.
I want people to ask "who did that for you" not "who did that to you".
Old 01-10-2014, 09:05 AM   #18
IntegraPLY/Paper Back Underlayment
Can anyone help me understand how the underlayment can be buckling. I sta[stapled with recommended staples on every X it down I used IntegraPLY/Paper Back Underlayment, It was stable and fine. a few days latter I installed the glue , let it dry as recommended for CVT and with in 24 hours the floor started to buckle. We pulled up the tile and could see it was the underlayment pulling away from the floor has anyone had that experience with away?
iraroffel is offline   Reply With Quote
Old 01-10-2014, 07:57 PM   #19
Retired Moderator
Rewards Points: 7,174
You should start a new thread for your question---we need to know if there is a moisture problem below that floor----sounds like water got under it or the room below might have a high moisture content---
How long are the staples?
Old 01-11-2014, 12:14 PM   #20
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,658
If the staples are too far apart or some aren't holding for whatever reason, the adhesive will make the underlayment bubble.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-24-2018, 08:03 AM   #21
DPP
I need to lay sheet vinyl in my basement near the exterior door. The subfloor is concrete. Do I need to use a moisture barrier since it is basement and near an exterior door.
What type of underlayments is recommended for this project?
Thanks in advance..!
DPP is offline   Reply With Quote
Old 06-28-2018, 11:15 AM   #22
Re: underlayment materials for vinyl sheet flooring in bathroom
Vinyl is normally installed directly on the concrete. But if you have a moisture problem, that needs to be addressed first and not with a moisture barrier. Water will collect under a moisture barrier and grow mold.
bathroom flooring carebear560 Flooring 9 07-24-2012 07:12 PM
Bathroom Flooring bbrown92y Flooring 10 05-27-2008 10:49 AM
Advice on installing bathroom floor fourstringdrums Flooring 8 02-26-2007 01:56 PM
Laminate Flooring - Is It Installed Under Bathroom Cabinets? BDPNA Plumbing 92 02-07-2007 12:02 PM
underlayment for quickstep laminate flooring Pturner Flooring 5 05-30-2005 04:09 AM
