Underlayment Interrogation - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 12-31-2017, 10:38 AM   #1
Rewards Points: 96
Underlayment interrogation
Hey guys,
I'm planning on installing laminated flooring on concrete in my basement.
I did a lot of researches and from what I understood, I need to install a vapor barrier first, a padding (underlayment) and then the laminated floor... Is that right?
Now, it's not always clear if some underlayment padding act as vapor barrier as well.
I'd like to purchase this padding for all his features.
http://www.robertsconsolidated.com/w...H2515-9076.pdf
Can you confirm if with this underlayment, I need to install a vapor barrier made of polyethylene?
Also, if I was going to install a rubber floor in my mechanical room, should I use the exact same combination of underlayment and vapor barrier?
Happy new year to you all!
martynator is offline   Reply With Quote
Old 12-31-2017, 12:03 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,268
Re: Underlayment interrogation
Roberts underlayment is fine. However, you may want to consult with the flooring manufacturer to see what they recommend for warranty purposes. I also question laminate in a basement. The rubber floor may not call for underlayment. Again, check the manufacturer's website for that. If they do, then the Roberts will work fine.
joecaption likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
1/2" sublfoor...what underlayment for hardwood? Jrhenry24 Flooring 10 10-04-2012 07:57 PM
concrete tile roof underlayment recommendations?? bobinphx Roofing/Siding 9 08-14-2012 10:20 PM
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 02:38 PM
Underlayment question-- "extending" existing underlayment fastener and type cbrc5eric Flooring 9 06-01-2011 04:03 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
