Ugly Tile With Hydronic Heat - Flooring - DIY Chatroom Home Improvement Forum
Old 08-24-2014, 08:51 PM   #1
Ugly tile with hydronic heat
I currently live in a house that has very ugly tile flooring. I'd love to rip it out & expose the hardwood underneath, but the room's heating source is the hydronic system embedded in the concrete base of the tiles. Needless to say, I'm trying to think of some simple solutions.
Could one solution possibly be using floor leveler to even up the the grout lines and then covering with linoleum?
coachrau is offline   Reply With Quote
Old 08-24-2014, 09:02 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Possibly !!! So you are talking about ceramic tile???
I'm thinking going to vinyl the adhesive may not be compatible with the heat source.
What exactly is under the tile? What are the layers? The tiles should be separate from the concrete base containing the heat system, the tiles should have been applied with their own adhesive product and therefore should be removable. I said "should be".
You should provide us with a better description of what you are working with if we are going to be able to help you.
XXX
Old 08-26-2014, 08:34 PM   #3
Thanks for getting back to me. Upon further review, I looked and saw that there is the layer of ceramic tile and then the concrete base. Would I have to worry about hitting the hoses or is that pretty tough to do?
Old 08-26-2014, 09:16 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay I'm kinda slow on the uptake here.
You say you have hydronic heat imbedded in concrete. Then you say you have a wood floor. Then you say the wood is covered with ceramic tile.
  1. How do you know you have hot water heat in the concrete?
  2. Where is this wood floor in this recipe and what kind of wood is it?
  3. Is it typical slat flooring?
  4. How is the wood flooring attached to whatever it is attached to?
The tile should be installed with a thin application of what looks like concrete but technically is not.
Yes that could be a big worry until you can determine what is down there and how.
XXX
Old 08-26-2014, 09:37 PM   #5
Didn't say anything about wood flooring, but thanks for the help nonetheless.
Old 08-26-2014, 09:41 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You didn't say that? Then who did?
XXX
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 10:56 AM
heat mat & ceramic tile in bathroom jpaz Flooring 1 02-19-2013 11:08 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Ugly tile, but I don't want to replace gingerbo Tiling, ceramics, marble 5 11-27-2009 10:43 PM
