Turn Concrete Foundation Into Finished Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 12-26-2016, 06:06 PM   #1
Rewards Points: 262
Question
Turn concrete foundation into finished floor
I want to remove some carpet and do whatever needs to be done to the concrete foundation to make it a nice concrete bedroom floor.
Where do I begin?
1. clear room
2. remove carpet
3. ?
4. ?
This looks nice.....
http://concretefloorpolisher.co.uk/w...6-1024x683.jpg
Jamesonc is offline   Reply With Quote
Old 12-26-2016, 06:34 PM   #2
Concrete & Masonry
Rewards Points: 344
Re: Turn concrete foundation into finished floor
THe image in the link appears to be brand new concrete that was power-troweled, and has a high build sealer over it. Polished is generally ground, at least minimally.
Your options are going to depend on what kind of shape your existing floor is in. Most were never intended to be exposed, so contoling cracks by sawing the floor right ater it was poured was rarely done. Aslo depends on if the carpet was glued down or not.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Jamesonc (12-26-2016)
Old 12-26-2016, 06:37 PM   #3
Rewards Points: 1,550
Choose an epoxy scheme you like, a reputable contractor and pay him do it. These jobs aren't really a DIY task so leave this one up to the professionals. There will be plenty of DIY jobs for you later.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 12-26-2016, 07:15 PM   #4
Rewards Points: 262
In other words, cross this one off the list. Thank you for input.
Old 02-15-2017, 07:21 PM   #5
Rewards Points: 2
Don't give up yet! I pulled up the carpet in my bedrooms and acid stained them by myself. I caught a break that the carpet wasn't glued down. The one thing I didn't like was the little divots that popped out of the concrete when I pulled up the tack strips. Probably should've used a leveler on the floor to get rid of them, but was scared it would crack or flake off later. Soy gel took off the stain and paint that had gotten on the concrete during construction. Just followed the directions on the bottle for the acid staining and sealing. I really love it and it wears even better than I thought it would. Good luck.
primroselane is offline   Reply With Quote
Old 02-15-2017, 07:37 PM   #6
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,342
Just don't forget to supply anyone using that room some nice fresh fuzzy bunny slippers.
That's gonna be one cold floor.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Tags
carpet , concrete , floor
Expanding Foam Between Two Floor Joists Over Concrete Foundation Wall Howitzer Insulation 9 07-22-2016 07:37 AM
Trafficmaster Ceramica on pine finished floor KURTZU2 Flooring 4 03-06-2012 10:06 AM
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 03:27 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
cold concrete floor RuthP Flooring 4 02-03-2008 10:13 PM
